Beverage chillin' machine.
Ok, heres the deal. I want to buy a 5/10 gallon water cooler. I don't want to ever buy ice again. So heres the challenge. Adapt a cooler to be able to plug into an outlet or ALSO be able to be powered by batteries for when im camping to keep the water cold.
I thought about a PC water coolign system but i talked to a friend and said that will not work. so i come to the CD community. what shall i do? |
Re: Beverage chillin' machine.
For power, set it up to operate on either 12 volts (then use a 110 power supply) or 110 volts (then use a 12 volt to 110 volt inverter).
For coolness, you can use a classical refrigeration system (but heavy, relatively fragile) of Peltier devices (limited capacity for cooling, especially freezing). Peltiers need heat sinks, cooling fans and have a limited temperature differential, possibly requiring stacked units for the temperatures you want. Real water ice has a lot going for it. 10 pounds of it can take 288 ounces of liquid from 90 F down to 34 F in about an hour, and hold it there (in a commercial ice chest) for easily more than a day. The energy required to change phase from solid to liquid is considerable, so you are storing quite a bit of energy in that solid water - more than you might get out of a comparable weight of battery. The byproduct - water - is generally environmentally compatible. Don Last edited by DonRotolo : 15-09-2007 at 11:56. |
| pic: me chillin in chicago | its da PAT!!! | Chit-Chat | 3 | 22-02-2007 11:26 |
| One machine? | mzitz2k | General Forum | 19 | 03-03-2004 17:42 |
| Brazilian Machine | team_383 | General Forum | 1 | 22-01-2004 10:33 |
| Choosing a machine shop (Re: How important is a machine shop | archiver | 2001 | 9 | 24-06-2002 04:20 |
| The only thing I'll miss from nationals: Frozen Carbonated Beverage | asher | Chit-Chat | 22 | 30-04-2002 18:46 |
