[OCCRA]: Belt material and wheel modification
Hello,
We need a rules clarification: we would like to modify our wheels by gluing a more "grippy" material to the outside of them. In the Additional Materials list, we are allowed specifically to use sheet rubber; I would like to use wedge-top incline conveyor belt. While this could loosely be considered "sheet rubber" (it's in a sheet, and it's rubber, mostly) I want to be safe. Also, there are no apparent rules about what wheels can be made of, or for that matter what the definition of a wheel is (I know, don't lawyer...) So, is incline conveyor belt material, such as that on page 1189 of the McMaster-Carr online catalog allowed on our robot? Where do you draw the line between sheet rubber and not allowed? Thanks, Jacob Rau, OCCRA 43 (Holly Robotics) EDIT: Are similar products, such as no-slip rug backing, allowed per the "sheet rubber" rule? Last edited by JBotAlan : 18-09-2007 at 23:22. |
Re: [OCCRA]: Belt material and wheel modification
If the material is on the additional material list it is a legal material.
If the material is "sheet Rubber" then it is legal sheet rubber. If the material is named/sold as a "Widget" then it is not sheet rubber and is illegal as a Widget is not on the additional materials list. Its configuration of raw materials does not make it something it is not. Question: May we make wheels? Answer: Yes as long as the materials are on the additional materials list. Question: Can we use conveyer belt? Answer: Show me conveyer belt on the additional materials list. I only see V-Belts. Question: What is the definition of a wheel? Answer: Give Webster a try. Question: Is no slip rug backing sheet rubber? Answer: The product name answers the question. It is no slip rug backing. |
| [OCCRA]: Motor shaft modification | Alex Golec | OCCRA Q&A | 1 | 12-10-2005 21:39 |
| [OCCRA]: [OCCRA]: Material Donations | xzvrw2 | OCCRA | 2 | 17-09-2005 08:55 |
| Cheezy Poofs' Wheel Material | evolution | Technical Discussion | 6 | 18-04-2004 23:11 |
| type of material; conveyor belt | Alyssia | General Forum | 9 | 10-01-2003 13:06 |
