Go to Post I was considering letting Big Mike bearhug me for the warmth. - Barry Bonzack [more]
Unread 02-10-2007, 19:56
Krazykid's Avatar
Krazykid Krazykid is offline
Chairman of Construction
AKA: Lorenzo
None #0842 (Falcon Robotics)
Krazykid is an unknown quantity at this point
Vex Controllers....Temp
does any one know it a vex controller can take temperature measurement and if so what device would be most accurate. thank you
× қяαzуқιd ×
2004 FIRST'S Engineering Inspiration Award
2004 MATE Champions
2005 Arizona Regional Chairman's Award
2005 National Engineering Inspiration Award
2006 Arizona Regional Chairman's Award
2006 National Honorable Mention Chairman's Award
2006 MATE 2nd place, 1st in US
Unread 02-10-2007, 21:14
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Vex Controllers....Temp
I've had good luck with this sensor before:
http://www.national.com/mpf/LM/LM19.html
You should be able to interface it directly to an analog I/O port on the Vex controller.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 02-10-2007, 22:55
Gdeaver Gdeaver is offline
FRC #1640
What range of temps are you looking at? How much accuracy do you need. How fast will the system temp be changing (Delta T).
Unread 03-10-2007, 00:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'll bet it has to do with measuring the temperature of the water in the vicinity of the "serum"
http://www.h2orobots.org/fallmission.htm
Unread 03-10-2007, 10:04
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
There is a temperature sensor on the KOP Gyro board from 06/07.
Unread 03-10-2007, 15:20
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
That was a pretty random feature to add... I didn't even know that was there!
Hmm... maybe I'll add a "External Temperature" gauge to the OI pannel this year...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 03-10-2007, 15:27
AdamHeard's Avatar
Lead Mentor
-q
I believe it could be used to offset the gyro's reading based on temp (because temp affects it)... At least that is what one mentor was telling me.
Unread 03-10-2007, 15:48
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I dont have the datasheet on hand but that would make sense. If temperature affects the output of gyro it makes sense that they would tell you what the temperature was so that you could calculate the actual rotation.
Unread 10-10-2007, 02:48
Krazykid's Avatar
AKA: Lorenzo
yes sir you are completly right ive started my own team with quite a bit of success my organization name it P.I.U.E(Project for Improving Underwater Exploration) wer just a small team but i believe the members are what make us a good team since we all think out side tha triangle.
ps thank you for the great sujestions and this temp probe will be for undewaterand i want it to be as accurate as possible while keeping my the robot simple along with the code within it but i am open to any sujestions at this point have a good day every one!!!
× қяαzуқιd ×
2004 MATE Champions
Getting two Vex controllers to "talk" to each other thefro526 Programming 1 28-05-2007 11:59
Doubts about Gyro Temp capenga Programming 1 31-01-2007 16:59
Controllers? joshR515 Control System 1 21-02-2006 16:06
Need info on how to build temp. receiver and transmitter archiver 1999 5 23-06-2002 22:01
