Go to Post I also like how the FTC folks are able to get involved with the FRC process this year, but it's always a bit of a let down when you're told you can't launch things into the air. - s_forbes [more]
Unread 08-10-2007, 08:22
tommy_chai tommy_chai is offline
tommy_chai is an unknown quantity at this point
How to write image data to binary PGM file format(P5)?
Hi all,
I fail to write the image data to binary PGM format (P5).
Let's say i have to write a image data into PGM P5 format.
I have the information for width, height, Y_min, Y_max, XL, XR and the TEMPLATE1 (data matrix) ==>A region of interest from an image.
Y_min & Y_max = minimum and maximum of the height value.
XL & XR = min and max of the width value for the image.
First, i call the subroutine,
write_data_grey_binary(width1,height1,XL1,XR1,Y_mi n1,Y_max1,filename99[total],TEMPLATE1);
void write_data_grey_binary(width,height,XL,XR,Y_min,Y_ max,filename,output)
int width,height,XL,XR,Y_min,Y_max;
char *filename;
unsigned char** output;
int i,j,nread;
FILE *fp;
unsigned char* temp;
if((fp = fopen(filename,"w")) == NULL){
printf("File 333 output data can not open\n");
exit(1);
fprintf(fp,"P5\n%d %d\n%d\n",width,height,(GRYSCL-1));
temp = (unsigned char*)calloc(height*width, sizeof(unsigned char));
for(i=Y_min;i<=Y_max;i++){
for(j=XL;j<=XR;j++){
temp[(i*width)+j]= (unsigned char)output[i][j];
nread = fwrite((void*)temp, sizeof(unsigned char), (height*width), fp);
free(temp);
fclose(fp);
return(0);
However , i have an error at the line " temp[(i*width)+j]= (unsigned char)output[i][j]; ".
However, this coding can be ran when i want to write the full image like:
write_data_grey_binary(width,height,0,width-1,0,height-1,filename99[total],inpgrey);
Scouting Data Interchange Format proegssilb Scouting 7 06-06-2007 19:29
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
File Format Conversion Solidworks to Inventor coreyjon Inventor 2 21-01-2005 20:11
Standardized Scouting System/File Format phrontist General Forum 15 18-04-2004 17:05
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
