Go to Post by the way when someone calles me a dork or geek, i tell them to look up dork and geek in the dictionary, and that i would rather be called nerd :) - Mike Schroeder [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 20-10-2007, 08:04
surferacf's Avatar
surferacf surferacf is offline
Student Leader & Electrical Captain
AKA: Aaron F
FRC #3060 (The Fighting Tuna)
surferacf will become famous soon enough
Question [OCCRA]: Battery Charger Question
I noticed something interesting at the Walled Lake Tournament. Many teams were using the Charge Xpress Charger from FIRST, which puts out 12V at 6Amps.
However, the Pre-inspection form clearly indicates that approved chargers should put out at 4 Amps.
So my question is: Are these chargers legal and the Pre-Inspection form is wrong, or have we all been voilating the rules?
Unread 20-10-2007, 11:18
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: Battery Charger Question
The charger pictured is fine.... 4 amp is a better charge rate as per the battery mfg. The unit pictured will not damage the battery life.
The faster you charge a battery (higher amp) the shorter the life of the battery.
The use of automotive chargers that are 30 amp will damage the battery after just 1 or 2 charges. Additionally there is a fire hazard as the battery gets hot.
When charging the battery check the case as it should NOT get warm.
Mike Martus
On-Board Battery Charger bronxbomber92 Technical Discussion 6 08-02-2007 11:11
[OCCRA]: Question about the battery wbhsAndy OCCRA Q&A 1 24-10-2005 20:11
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
