Electronics Boards Designs/Ideas
This post is for teams who would like to post ideas about electronics board designs (Images) and ideas about them. You may show current, past ,and even future boards. Ideas can be from connectors to charging circuits it doesn't matter. This page is also to help new and old teams in design issues.
Please post as much as you can i will hold no secrets from you and show you my plans as soon as they are approved. Note: Please Don't post things multiple times |
Re: Electronics Boards Designs/Ideas
Well Now that i Have approval here is my design
![]() ![]() size 13x10x3ish 8 victors The fuses are mounted up sided down this allows you to remove the fuses without bending or disconnecting any wires. It also has what i call the stupid act which means no one can drop something inside or cross anything with their hands allowing for a safer board. This board also is set up to have the victors blow air over the internals to keep them cooler and last longer. note I'm aware that the distribution block has yet to be added but space is provided for it. |
Nice design!
Would the two polycarbnate pieces be attached in any way, or is the top piece simply just lying on top? (resting on the fuses, I'm guessing) I would think it would be somewhat of a nuissance if the two pieces of polycarbonate were indeed screwed/attached together somehow, or else it wouldn't be easy access to get to the fuses OR the victors.. I can just imagine the mayhem of wires going through this baby. Beauuutiful ![]() |
There would be 4 supporting pillars that would attach the two boards but i wanted to wait until i could import the distribution block in to inventor 7 to see their placement.
But your are right the wiring would be hard and require a day or two. Last edited by BlackShadowFox : 21-10-2007 at 12:59. |
nice board, but where is your controller?
a little bit cramp but still a great looking board. |
#7
WOW, i look at all the designs and they are amazing. My boards don't look like that, don't get me wrong my boards look very very neats and everything is arranged in the optimal positions, but what you guys do is just artwork.
#8
Originally i had the controller mounted above the fuses, but i took the controller off so it could be mounted separately. This would make it easier to change fuses and to wire neatly. I could always turn the board upside down and mount the controller on the bottom (which would then be the top)
#9
how do you make your electronics board?
just keep programming the same old thing every time over and over and over.... |
| Camera Boards | Inoperational | Programming | 6 | 20-01-2007 12:57 |
| OI Boards? | Jake M | Robot Showcase | 1 | 28-11-2006 20:02 |
| pic: Team 254 Electronics Boards | Cory | Robot Showcase | 15 | 20-02-2006 22:48 |
| Pros and cons of electronics boards/boxes | RbtGal1351 | Electrical | 19 | 20-11-2005 15:01 |
| Control Boards | tenfour | General Forum | 3 | 01-03-2004 20:01 |
