Go to Post If you need more complicated control... make it more complicated yourself. ;) - Ryan M. [more]
Unread 21-10-2007, 17:02
BlackShadowFox's Avatar
BlackShadowFox BlackShadowFox is offline
AKA: Madwolvez
FRC #0401
Team Role: Electrical
BlackShadowFox has a spectacular aura aboutBlackShadowFox has a spectacular aura about
Send a message via AIM to BlackShadowFox
Cart Is Pit?
For the past summer i have been thinking about what would help my team while bring at the competition.
In order to help my team my friends and I have developed a concept of "Cart is Pit". Meaning that the cart will house must of all the tools/supplies that are usually in the pit. So when you go down to the floor if you need a tool it would be with your robot before and after the rounds and their would be no need for fetchers.
Carts basic components:
Electrical
I had design this system to have the robot batteries being charged on the cart at all times even when your not near a Ac power source. To go along with that it provides a AC and DC lines for charging laptops and running some electrical tools depending on cart battery size and inverter being used.
Safety
spare glasses, ear plugs, fire extinguisher, and first aid kit.
Tools
all necessary tools for the robot with the addition of some that others may be use if room is present.
Supplies
Spare electronics material
pre made parts
pneumatics stuff
Programing
Computers would have a multipurpose port that will allow the programmer to program their robot and not be next to it. (on the controller is prog and reset pins that would be in the cable to the programmer's station allowing him to control things with out getting in the way of the mechanical team).
Air
Built in large tank that will be full all the time.
robot pressure will be equalized with this tank then pumped independently allowing for a quick pump.
air could also be used in cleaning off dusk and etc.
If all this could be done then your 10x10 foot pit would have more room making it safer. Also everything you would need would be with the robot except for big tools such as mills and etc.
Please post more ideas, however don't say anything about a sound system because FIRST has ruled against it.
More Ideas
The last question is if all this is legal or illegal
Unread 21-10-2007, 18:54
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Cart Is Pit?
something that allows you to work under the robot would be nice. (maybe a small aluminum frame with 2 foot tall legs to hold it up while a team mate goes under to work on it.)
this is really a great design, one thing I would worry about though is its manueverability. We did not have a good cart last year but it was better than nothing(it was a furniture mover with some plywood bolted onto it.
thanks, vivek
"we don't build robots, we build people"
Unread 21-10-2007, 19:22
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Cart Is Pit?
Ditto to vivek's post. I've seen multi-purpose carts that have the ability to lift the robot, or have some kind of ramp that it sits on. Reminds me that I need to start working on some type of electrical system for us, with the battery, laptops, and whatnot. And find a canopy to cover the pit.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 21-10-2007, 19:46
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: Cart Is Pit?
also remember the cart has to be able to cross those cable cover things so making it heavy would be not be the best idea
...forest
Unread 21-10-2007, 19:50
AKA: Madwolvez
FRC #0401
Re: Cart Is Pit?
True i forgot all about those things.
hmmmmmmm how to make sure it would be light enough but also strong enough while keeping these features?
Are you sure about the air system?
Unread 21-10-2007, 20:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Cart Is Pit?
Yup. See <R101> The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used
to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the
playing field. Off-board compressors must be controlled and powered by the ROBOT. The
only difference between an on- and off-board compressor is that the off-board compressor is
physically removed from the ROBOT. Note: the intent of this rule is to permit teams to take
advantage of the weight savings associated with keeping the compressor off-board. But
using the compressor off-board of the ROBOT does NOT permit non-compliance with any
other applicable rules.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-10-2007, 22:05
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Re: Cart Is Pit?
Edit: Peter beat me to it. He needs to seriously get IM.
Peter, what about having two compressors? The KOP one for charging the robot, and the big compressor for the big tank? Having air for cleaning and whatnot is still pretty handy.
Unread 21-10-2007, 22:23
vivek16's Avatar
AKA: vivek
Re: Cart Is Pit?
@geeknerd99
I think that those little canisters of compressed air are really handy for getting dust off and cleaning. Also you can use them to cool down things by holding them upside down(engines and such.) Im not sure how good that is for the engines but it might help.
-vivek
Unread 21-10-2007, 22:27
geeknerd99's Avatar
Fire Hazard
AKA: Daniel Lin
Re: Cart Is Pit?
Originally Posted by vivek16 View Post
@geeknerd99
-vivek
What about air powered goodness? Like drills? And just the general bling factor of having air onboard cart?
And it's not just compressed air in those cans. They actually make me pretty woozy if I spray too much in an area that pretty much isn't outside.
Unread 22-10-2007, 03:37
Cory's Avatar
AKA: Cory McBride
Re: Cart Is Pit?
Compressed air is good for blowing chips and junk out of the robot.
However, those little pancake air compressors (which are just about the only thing small enough that you could fit into a cart) will not run any air tools for more than a couple seconds before they lose so much pressure as to basically be ineffective.
2001-2004: Team 100
Unread 21-10-2007, 22:31
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Cart Is Pit?
I have always wondered about air tanks and what not... I have also wondered about fog machines... are you allowed fog machines?? (obviously not for practical use) but compressed air would be wonderful to clean off work space at the end of the day (or during the day for that matter)
Unread 21-10-2007, 22:56
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Cart Is Pit?
I JUST HAD A BRAIN FART!!!!! who saw the mythbusters episode with the hovercrafts? you think 6 leaf blowers would lift 600 pounds?
Championship - Delphi "Driving Tomorrows Technology"
Unread 21-10-2007, 23:03
fimmel's Avatar
AKA: Forest Immel
Re: Cart Is Pit?
man that is a good idea lol....build one like adam's lilypad it would be quite stable lol
Unread 22-10-2007, 00:24
Re: Cart Is Pit?
Didn't see that, but I saw team 1006's 2006 robot moving device: 1 leaf blower was enough to lift their robot at full weight. Need I say more? (Though you would have the directing problem, but that's what the other drive team members are for.)
Also, remember to put space for the operator interface. The OI is (can be) a very awkward piece of equipment, if it's long or in multiple pieces. It's easier to put it on the cart if possible.
Unread 22-10-2007, 05:59
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Exclamation Re: Cart Is Pit?
"I had design this system to have the robot batteries being charged on the cart at all times even when your not near a Ac power source. To go along with that it provides a AC and DC lines for charging laptops and running some electrical tools depending on cart battery size and inverter being used."
I reference to the above information, be careful about doing this as we tried to do the same thing on a carrier that we built on year and we can to find out that the setup burned up three battery chargers running thru a AC to DC converter because the wave signal was different that the wave from the AC outlet. Just a thought from the past.
A clean pit is a happy pit. Kyle Love Chit-Chat 8 27-10-2007 13:59
pic: 1029 cart - Rene de Cart bjimster1 Extra Discussion 6 03-03-2007 20:47
robot cart button boy 1100 General Forum 7 06-12-2005 22:25
Lift on cart loomisman General Forum 9 21-11-2005 16:13
cart Nick Mac Pneumatics 1 25-04-2005 15:10
