Go to Post Don't take things too seriously; It's supposed to be fun. :) - ScoutingNerd175 [more]
View Poll Results: What was your final gear ratio on your drive?
< 10:1 (not inclusive) 0 0%
10:1 (inclusive) to 12:1 (not inclusive) 0 0%
12:1 (KOP) 6 37.50%
12:1 (not inclusive) to 15:1 (inclusive) 2 12.50%
> 15:1 (not inclusive) 4 25.00%
Multispeed (Post your gear ratios) 4 25.00%
Voters: 16. You may not vote on this poll
Unread 10-11-2007, 23:35
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Last Year's Gear Ratio
Ok, so on your drive, what was your final gear ratio after gearbox and sprocket reduction. Keep in mind that the KOP transmissions are about 12:1. (Assuming a 6" wheel size with four CIMs. If anything else, please specify)
<10:1
>10:1 and <12:1
12:1
>12:1 and <15:1
>15:1
If you used multispeed gearboxes, post your ratios.
269 used a 15:1 ratio using worm gears.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-11-2007, 23:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Last Year's Gear Ratio
For this to be meaningful, you also need to describe wheel size....
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
16:1, banebots with the added stage, 6" wheels.
Unread 11-11-2007, 00:34
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Also for this to be meaningful, you may want to consider which motors are being used for driving. While many use CIM's, some also use FP's and/or the mini-bike CIM (fat chip). Therefore the gear ratios used for those motors should not be compared with other motors.
We used 12:1 Banebots with the DUAL CIM configuration and additional 1.3:1 geardown to the 6" wheels for a total of about 16:1. The results end up with 6.25 ft/s at 40 Amp draw and 9 ft/s at free speed. No shifters last year.
Unread 11-11-2007, 01:17
AdamHeard's Avatar
Lead Mentor
We had a Small CIM, big CIM and FP w/ AM planetary on each side. The ratio of the Small CIM (which the other motors were matched to) was about 12:1.
This was driving 6 inch wheels.
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Help with gear ratio Wayne C. General Forum 6 26-01-2004 12:30
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
gearing for last year's gear cluster for the chipuhua motor Antonio Motors 0 07-01-2003 15:31
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
