Go to Post Messy wires are a pain in the chassis - [more]
Go Back   Chief Delphi > Other > VEX
Unread 14-11-2007, 11:30
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Running program without transmitter
Is it possible to put the vex controller into an 'autonomous only' mode, like the FRC controllers when you set the team number to 0. I want to be able to run my vex controller totally autonomously and not have to have the transmitter connected
Unread 14-11-2007, 12:51
Re: Running program without transmitter
Look in main.c before the infinite loop:
#if ENABLE_AUTONOMOUS_MODE
txdata.user_cmd = 0x02; /* Tell master you want to be in auton mode. */
#endif
Unread 14-11-2007, 13:22
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
we had this same problem!! if you are using EasyC, you MUST program with the Easyc FOR vex, even though EasyC Pro will work, it will require the transmitter to not only be connected, but the radio must be turned on aswell...
let me know if this was your problem..
Unread 15-11-2007, 23:41
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Thanks for the responses, I just ended up using kevin watson pwm drivers to drive the servos, since it doesnt go through the master proc. i can control everything i need without the transmitter
Running the robot without a tether Hiromi Technical Discussion 3 05-10-2007 08:37
transmitter question??? mechanicalbrain Control System 1 23-04-2005 16:55
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
FM radio transmitter Alexander McGee Electrical 11 29-10-2003 19:41
How to keep a program running at a school which doesn't get it? Jimmy General Forum 9 03-04-2003 10:08
