Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 15-11-2007, 09:02
Jimmy_Team7011 Jimmy_Team7011 is offline
FTC #7011
Jimmy_Team7011 is an unknown quantity at this point
EasyC Downloading Problem
I am having some issues while downloading the Program, using the Intelitek loader, at the bottom of the browser, we can see FRC , while the rigth thing to "show", is VEX, but i am not able to change it, how can i change this "setup" to VEX???
Unread 15-11-2007, 10:21
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Re: EasyC Downloading Problem
Hi Jimmy,
This points to an installation problem. Completely uninstall easyC from the PC, and remove the folder. Then, reinstall using the version from the site: www.intelitekdownloads.com/easyCV2. Please make sure you install as an administrator of the PC.
If that does not work, please go to the Loader Setup and uncheck "Verify and Download" and try to download code again.
Thanks!
Jessica
intelitek Support
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Problem downloading code Romeo1351 FIRST Tech Challenge 6 01-12-2006 06:33
Problem Downloading from Streamline petek Inventor 2 10-03-2005 21:07
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Beginner problem with downloading pagemauck Programming 2 17-01-2004 13:24
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
