Lokking for older 2005-2007 posts
I was looking for some posts that I recall regarding a cool idea for breaking out the signals from the operator interface onto a custom board so you could easily prototype up switches, leds, joysticks, pots, connected to the OI.
While searching the forums, I found that all the forums seem to start around August 2007. The archives stop at 2002. Was there a big cleanup? Did stuff get lost? Will it be comming back in an archive? Thanks, Eric Anderson Team 1425 |
Re: Lokking for older 2005-2007 posts
Eric:
How did you look? There is a lot there from before August 2007. At the bottom of the list of threads there is a selecter for you to view things that have not been active in the past month. If you change the date to view in the last year, or from the beginning, you may find more. Or do a search from the orange bar with some keywords. Good luck! Last edited by Cynette : 04-12-2007 at 15:35. |
At the bottom of the screen, there are settings for display options, one of which is show threads from the, and a drop down. It sounds like yours is set to 100 days, and you want it set to "the beginning".
You may want to consider using the search function rather then manually sorting through threads (there are over 3200 threads in programming). I think team 116 may have been the team that did what you are describing. Last edited by Joe Ross : 04-12-2007 at 15:33. |
Thanks for the quick responses. I was using search, but I couldn't remember the right key words. I was looking in the control systems forum for some inspiration, but noted that I could not see back as far as I thought I should.
I fixed my profile to eliminate the cutoff for now. I found what I was looking for. Joe is correct, it was Team 116's Operator Interface Adapter Board. Thanks again. Looking forward to the 2008 Season!!! Eric Anderson Team 1425 - Error Code Xero |
| Calling for posts of divisonal stats... | chrisrobin | Championship Event | 0 | 18-04-2007 18:55 |
| pic: 2005 to 2007 | TrippyMohan | Extra Discussion | 1 | 20-03-2007 19:58 |
| Looking for a CAD program that will run on an older comp | Cuog | Inventor | 3 | 10-12-2005 18:44 |
| Suggestion for Delphi Programming Posts | Chris Hibner | CD Forum Support | 1 | 27-07-2005 10:02 |
| Rookie teams post numbers here! Older teams look for teams to mentor here! | Erodge | General Forum | 1 | 07-10-2002 13:40 |
