Go to Post I personally think any student should be allowed to participate, as long as he/she is helpful and active. FIRST, to me, is about inspiration, not elitism. - Aignam [more]
Unread 21-12-2007, 19:56
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
NEW IR board?
Does anyone know where to buy a new IR board or a new 5v regulator?
Thanks
Unread 21-12-2007, 21:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: NEW IR board?
LM78L05 regulators are about as standard as you can get. Just about any store you can find with a reasonable selection of electronic parts should have them. I'd try Radioshack, Fry's or your neighborhood electronics hobby shop.
Unread 21-12-2007, 21:18
Aren_Hill's Avatar
Build Nifty Things
Re: NEW IR board?
Yes sir, Thank you sir
A guy who likes robots.
Unread 05-01-2008, 14:47
Sirius Sirius is offline
FRC #1276 (Kaizen Blitz)
Sirius is an unknown quantity at this point
Re: NEW IR board?
We have tried to program the IR board with no success. Tried multiple remotes..no go. The IR board error LED lights when we power up the board with the learn button pressed for 2 second and goes out when the button is released and the CMD0 LED comes on. Then pushing the 1 button on the remotes, nothing happens. Have tried at least a dozen different TV types using a Radio Shack Universal remote. Looked at the signals coming out of S1 the IR receiver IC and see good solid 5v to 0v transitions. The FIRST IR board must be bad (maybe static damage to the micro from handling). Where do we buy another board? Tried to email the designer Bob Grieb but it bounced.
Unread 05-01-2008, 16:28
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
Re: NEW IR board?
Have you tried using the volume or channel buttons on the remote? The 1 button usually only sends out a single signal, while the volume and channel buttons send out a repetitive signal. Also, as far as i know at the moment you cannot purchase these boards. Your only bet would be to contact FIRST.
Unread 05-01-2008, 16:33
Re: NEW IR board?
Yes, we have tried that. When the scope is hooked up we can see that for some TV codes, the numeric buttons send continuous signals while for other codes the data are sent once and then a different signal that looks like just a sync is sent repeatedly. Neither of these seem to work in the learn mode.
Unread 05-01-2008, 18:39
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: NEW IR board?
Did you remember to send 2 teaching pulses for each button?
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 05-01-2008, 18:45
Re: NEW IR board?
As I understand it, you hold down the desired remote button until the CMD LED goes out then release the button, then when it light again push it again. The LED never goes out so we don't get to the second step.
Unread 05-01-2008, 18:50
popo308's Avatar
AKA: Brent
Re: NEW IR board?
go to the FIRST site and FRC support - Email us
you can get another one
we just got a new one
Unread 05-01-2008, 19:03
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: NEW IR board?
Have you tried any other remotes? I remember them saying that it may not be compatible with all remotes. Also, ambiant light could be causing interferance.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 06-01-2008, 15:39
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Re: NEW IR board?
Our IR card does not seem to be responding at all. When we try to power it up no lights come on. Has anyone else had this problem? Any Solutions?
Thanks
Unread 06-01-2008, 21:20
kspencer kspencer is offline
FRC #1783
kspencer is an unknown quantity at this point
Re: NEW IR board?
We are having the same problem. We have tried 3 different batteries - 7.2 volt, 9 volt and 12 volt and don't get a response.
Unread 09-01-2008, 18:40
wexlerd1 wexlerd1 is offline
FRC #2547
wexlerd1 is an unknown quantity at this point
Re: NEW IR board?
We have the same problem - the error light flashed once, then nothing. How do we know whether pin 1 or pin 2 connects to the battery's positive or negative pole? Is it possible we burned it out (there was no smell)? If others are having similar problems, could the IR board be defective? If so, where do I go for a replacement? I assume I don't need the same model.
Rookie Team 2547
New Indiana FIRST Board of Directors President Andy Baker General Forum 5 06-11-2005 22:42
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Come visit team 121's new message board! archiver 2000 1 24-06-2002 00:39
