Go to Post So NASA is planning on blasting NERD deep into space? - Joe Matt [more]
Unread 01-01-2008, 16:37
guy_rom guy_rom is offline
guy_rom is an unknown quantity at this point
aux analog
whats the aux analog on the joystick?
Unread 01-01-2008, 16:44
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: aux analog
on the KOP white joysticks it is connected to a series of resistors that connect to the thumb switch on the handle. connect one to the OI and read the values from the dashboard.
if i had one in front of me i would look it up myself but there in storage right now
Unread 01-01-2008, 17:23
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: aux analog
Traditionally, on analog joysticks the AUX channel was tied to a throddle control, for flight simulators. In some other joysticks, its tied to the hat switch, such as the white(current?)KoP joysticks. If you make a custom controller, linear pots still work on this channel, so your really unlimited in what you can do with it.
Unread 01-01-2008, 19:56
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: aux analog
I'm assuming you are using the white joystick from the KOP, so here it goes. It is kind of hard to describe the positioning of them, but if I remember correctly on the top of the joystick there is a button that acts sort of as another joystick, you can push forward, left, etc. A little down and left from that, there are two buttons, above and below eachother. One of these is aux 1, the other is aux2, but I cant remember which is which. To use these buttons, assuming you have the joystick into port 1, would be p1_sw_aux1 (or aux2). That is all I can remember right now, hope it helps.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 01-01-2008, 23:54
Re: aux analog
Everyone so far has been describing the WHEEL input. The AUX analog is a pin on the OI's joystick port that isn't connected to anything in either the old black CH Flightsticks or the new white A/B joysticks. You can attach your own 100K variable resistor to it if you want.
OI LEDs on the 5v Aux ShadowFireGT Control System 7 25-02-2007 08:05
Aux 1 & 2 WGRAY Programming 1 12-02-2007 14:59
OI Aux Fault light red Vashts6583 Control System 1 25-01-2006 23:10
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
