Trackballs
What types and what retailers carry the balls required for this year's game?
Re: Trackballs
Are they like the yellow exercise balls that the FVC used last year?
Re: Trackballs
anybody have the FRC trackball specs? diameter anybody? weight?
Re: Trackballs
They said the diameter was 40 inches. Don't know about the weight. |
Re: Trackballs
Thats a pretty huge ball... |
Re: Trackballs
40 inches in diameter, Weight is 10 pounds
#7
Re: Trackballs
Does anyone have a "disclosable" source for those balls.
Regards Frank |
#8
Re: Trackballs
I think it's time to return to slightly smaller field elements- last years rack couldn't be built anywhere due to space restrictions, and these balls are larger than the standard width of an aisleway! (30" according to ADA). And they cut very easily if you bounce them into a metal table. Sigh. |
#9
Re: Trackballs
I called FIRST yesterday and they said they'd release information on buying more either today or tomorrow.
#10
Does anyone know where we can order more track balls?
#11
Re: Trackballs
Update 3 does ...
#12
Does anyone know the PSI of the trackballs?
I see in update 4 that they weigh about 7.3 pounds, but one of our mentors wanted to know the PSI. Carolyn Hinckley |
#13
Re: Trackballs
PSI doesn't matter. Check Q&A and they'll tell you the same thing. It's the size that matters. I suppose if you really want to know the PSI, you could inflate one to the right size using a pump with a gauge on it and check that.
#14
Re: Trackballs
From the way they looked in the video i don't think they are like the exercise balls. they look like a bladder covered in some sort of cloth. they are also 10 pounds when they're inflated.
Any idea where we can get them? |
#15
Re: Trackballs
The game pieces, known as “TRACKBALLS,” are large balls made of an inflatable plastic bladder and an outer fabric covering. When inflated, each TRACKBALL is approximately 40 inches in diameter, and weighs approximately 10 pounds. Two TRACKBALLS of each alliance color, red and blue, are in the arena during the MATCH. One TRACKBALL of each color will be marked with a set of six-inch diameter white dots so that it may be uniquely identified for tracking purposes during the match. |
