OVERDRIVE Rules/Scoring Questions
I didn't see a general discussion forum about this years rules, so I guess this is it.
My current question is: Are the trackball points awarded by color of the ball, or color of the team controlling it? i.e. - If Blue knocks down a red trackball during hybrid mode, does blue then get the points? What about crossing lines? I think that if the ball colors are for ID purposes only, like the white dots, then creating a scoring sim (like my annual spreadsheet...) is next to impossible! ![]() Last edited by cbudrecki : 05-01-2008 at 13:59. |
Re: OVERDRIVE Rules/Scoring Questions
If you look in the manual it shows you the different ways to score
but color it alliance blue, and red if the ball goes over the crossbar you get 8 points. Under is 2 points You also get 8 points if you get the ball off during hybrid mode. |
<G08> All TRACKBALL scores are awarded to the ALLIANCE associated with the scored TRACKBALL, independent of the ROBOT that may have caused the scoring action to occur.
In reply to the trackball removal:
<G08> All TRACKBALL scores are awarded to the ALLIANCE associated with the scored TRACKBALL, independent of the ROBOT that may have caused the scoring action to occur. |
what are the rules for the defence , yes rubbing is racing , but how hard can someone hit or " nudge"
#7
See <G37> for defense rules.
It sounds like you can only accidently hit someone, or "nudge" when wanting to pass. |
#8
yes , but I wonder what the limits are , if you remember in AIM HIGH , there was robot carnage , this game you have to have bumpers , so what are the limits on pushing and shoving , can someone really play defence aside from just giving someone a " nudge"
#9
<G37> a. High speed accidental collisions are likely to occur during the MATCH, and are an expected part of the game. However, high-speed intentional ramming is not acceptable and will be penalized.
b. Contact within the BUMPER ZONE is generally acceptable. c. Contact outside of the BUMPER ZONE is generally not acceptable, and will result in a PENALTY. The offending ROBOT may be disqualified from the MATCH if the offense is particularly egregious or if it results in substantial damage to another ROBOT. However, incidental contact outside of the BUMPER ZONE will not be penalized. It seems as if you can hit someone else as hard as you want, as long as it's on the bumper, and as long as you don't seem to be aiming for them (ramming). |
#10
Posting in response to the color ball question. If you look at the scoring chart regardless of ball color in hybrid period. You get 8 points per trackball knocked off of overpass. The rule your refering to should only apply to balls during the control period. Thats if your on the blue team and knock a red teams ball past the finish line during the match the red team gets the 2 points for the ball. It's real confusing because you could take that scorring chart either way.
#11
<G09> During the HYBRID PERIOD, each TRACKBALL that is removed from the OVERPASS (i.e. completely removed from its initial TARGET LOCATION and not in contact with any portions of the OVERPASS) at the end of the HYBRID PERIOD will earn 8 points. You get 8 points per trackball OF YOUR COLOR that is knocked off in Hyrbrid mode. |
#12
And per this chart on the rules ![]() note summarized Last edited by Matthew2c4u : 05-01-2008 at 17:39. |
#13
What does "above the overpass" mean? Does it mean over without touching, or can it touch the overpass? If it can touch, then what happens when you put your trackball on top of it at the end and your opponent knocks it off? Do you get 6 points for the trackball crossing over the overpass?
#15
No one seemed to know the answer in another threads so I'll try here.
I wonder what the refs will do if a robot breaks down in the middle of the track, thereby obstructing it. Will it be a penalty? During the Kickoff broadcast, they gave a brief tutorial about the IR board. They said that different remotes can disrupt the receptors. Does this mean that the robocoaches can disrupt another team's IR board? During the game practice, two red "bots" passed the trackballs back and forth. On would lift it over the bar and then the other would pass it back. Could you hypothetically do this the entire game, as long as you are not obstructing the path? Also is there anywhere where we can find the tests that the refs will be using so that we can see what penalties they focus on the most? |
| Rules Questions | Eric W. Jones | Rules/Strategy | 145 | 07-01-2007 23:24 |
| rules questions... | archiver | 2001 | 5 | 23-06-2002 22:40 |
| scoring questions | archiver | 2000 | 3 | 23-06-2002 22:28 |
| Questions on rules | nick reynolds | Rules/Strategy | 1 | 08-01-2002 01:02 |
| Questions about rules | ahecht | Rules/Strategy | 9 | 07-01-2002 22:45 |
