Go to Post FIRST is good for us. It is good for our own Children. Don't give up, even if you are as tired as I am! - Kyle Hughes [more]
Unread 05-01-2008, 19:04
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Skid Steer system
Does anyone know how to build a Skid Steer (SS) system? And if so could you explain it to me? Thanks
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 11-01-2008, 17:40
MiniNerd24's Avatar
Re: Skid Steer system
I think that I might need to close this thread.
but i will make sure that I ask for your help.
The system is down.
Unread 17-01-2008, 15:48
MiniNerd24's Avatar
close thread
The system is down.
Unread 18-01-2008, 21:06
MiniNerd24's Avatar
fine
I won't use this topic then.
Can anyone tell me how to use the MPLAB simulator? I have the PDF but it's not really helpful, especially since I keep getting the "check build tool options" message.
The system is down.
Unread 18-01-2008, 22:36
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
what you need to do is go under the toolsuite locations in the project pull down thing. Then go into the c18 compiler tab and make sure all the .exe files are correct. For a more complete description of how they are supposed to look, look at our teams' forums I posted something just like this here http://www.team340.org/smf/index.php?topic=241.0
Unread 19-01-2008, 10:49
MiniNerd24's Avatar
Thanks for the help. I just couldn't get that thing to work.
(Sorry that this is under a drive train thread I couldn't get this to close )
The system is down.
Unread 05-01-2008, 19:18
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Correct me if I'm wrong, but "swerve" aka crab steering is very differant than skid steering.
Skid steering is when you have, for example a simple four wheel set up. The left side of your drive train is isolated from the right side, and both can be controlled independantly. The term "skid steer" derives from the fact that when you turn with this type of configurartion, your tires "skid" along the ground. Depending on ths surface, and wheels you choose, this type of drivetrain can put a lot of load on your motors, and stress on your overall drivetrain. A few years ago, we had a problem with too much traction using a simple skid steer setup, and had to put zip-ties on the tires to reduce the ammount of traction we had.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 05-01-2008, 19:41
MiniNerd24's Avatar
Really. thanks i guess I hadn't thought about the load on the motors.
The system is down.
Unread 05-01-2008, 20:18
coreyjon's Avatar
Flight Engineer
Hmm, poster number 2 deleted his post, making my post a little awkward. Any more questions, feel free to ask.
pic: 648 Cardboard Crab Steer Boat 1 SgtMillhouse648 Extra Discussion 17 05-07-2007 23:14
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
Skid marks T967 General Forum 10 31-01-2003 07:24
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Skid Marks rynnieguy General Forum 2 14-02-2002 22:03
