Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
Unread 06-01-2008, 16:46
m1k3 m1k3 is offline
FRC #1396
m1k3 is an unknown quantity at this point
Double solonoids
Hey guys i have a question about the dual solonoid when your wiring it do you wire it to one spike or two spikes if its one spike how do you get it to extend and retract thanks!
Unread 06-01-2008, 16:58
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Re: Double solonoids
Remembering from last year, I think you connect the two black wires from the solenoid to ground (anywhere, not on a spike), and the two red wires go to the two outputs on a spike. You only need one.
Unread 06-01-2008, 17:17
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
YOU ONLY NEED ONE SPIKE. CHECK OUT THIS SPIKE MANUALCHECK OUT FIGURE 2
LAST YEAR WE USED TWO BUTTONS ON THE JOY STICK, ONE FOR EXTENSTION AND THE OTHER ONE FOR RETRACTION BUT IM SURE YOU CAN PROGRAM IT SO THAT ONE BUTTON ON THE JOYSTICK EXTENDS AND RETRACTS THE CYLINDER.
I WAS THE PNEUMATICS SUB-GROUP LEADER LAST YEAR SO IF YOU HAVE ANY QUESTIONS FEEL FREE TO EMAIL ME.
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 06-01-2008, 17:15
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You can hook it to a single Spike. Look at the drawing in the attachment.
For the programming, you would fire each solenoid by setting either side of the spike to 1. Ex:
//Start Compressor Code
relay8_fwd = !rc_dig_in18;  //Turn on the compressor when the pressure sensor is closed
relay8_rev = 0; //Without this, the compressor might run backwards or might not run at all
//End Compressor Code
//Start Pneumatic Piston Code
if (p1_sw_top == 1)  //If you press the thumb button on the joystick plugged into port one...
		relay1_rev = 0; //Turn off the extend side of the solenoid
		relay1_fwd = 1; //Turn on the retract side of the solenoid
if (p1_sw_trig == 1) //If you press the trigger on the joystick plugged into port one...
		relay1_fwd = 0; //Turn off the retract side of the solenoid
		relay1_rev = 1; //Turn on the extend side of the solenoid
//End Pneumatic Piston Code
With this code, you will plug the relay into relay port 1, the compressor into relay port 8, and the pressure sensor into digital i/o port 18.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Last edited by RyanN : 06-01-2008 at 18:02. Reason: Fixed a small error in my drawing.
Unread 06-01-2008, 17:20
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Originally Posted by RyanN View Post
You can hook it to a single Spike. Look at the drawing in the attachment. For the programming, you would fire each solenoid by setting either side of the spike to 1. Ex:
quick note you power going into the spike should be on the +12v and GND not M+ and M- ....just for clarification
...forest
Unread 06-01-2008, 17:50
RyanN's Avatar
RyanN
Oops, I'll fix that real quick and edit the post above. Thanks for pointing that out!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 06-01-2008, 19:36
FRC #1396
thanks alot i wuda put the groun to the spike lol
Unread 06-01-2008, 21:43
AKA: Eric VA
And thats what fuses are for
Double Helix Jimbo5051 Inventor 3 08-02-2006 20:10
FIRST Double Jeopardy 2.0! (8/27) EddieMcD Games/Trivia 1 29-08-2004 18:48
FIRST Double Jeopardy 2.0! (7/30) EddieMcD Games/Trivia 1 31-07-2004 19:08
FIRST Double Jeopardy! (3/30) EddieMcD Games/Trivia 2 31-03-2004 21:42
double solenoid gail OCCRA 0 11-10-2002 19:42
