Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 06-01-2008, 17:21
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Building an IR transmitter?*
Can anyone verify whether or not were allowed to build our own IR transmitter instead of using a TV remote?
(Srry for the repost the last thread was poorly named)
AdamBots.com- Winner of 7 Best Website Awards!
Unread 06-01-2008, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Building an IR transmitter?*
This is an opinion. For an answer which you can use at competition, use the official Q&A forum.
Yes, you can build your own (but why?), or modify a remote to have a higher IR light output. Just try not to have so much light you interfere with everything. A regular remote should be workable from 50 feet, you might have to try 3 or 4 before you find one.
Don
Unread 06-01-2008, 18:28
xanarchyx xanarchyx is offline
Capt' of Manipulator
AKA: Collin Matthews
FRC #1714 (More Robotics)
xanarchyx is an unknown quantity at this point
if you want more range or power, just add another 1 or 2 IR LEDs in parallel with the one(s) in the remote. make sure that they are aimed like the other one and use the same voltage. also the same wavelength might be needed, not sure on that tho.
Unread 06-01-2008, 18:42
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Yes, that would be the most advisable solution. just add more IR LED's to increase the range (and perhaps power too).
Unread 06-01-2008, 23:41
HighLife's Avatar
No, I was thinking more along the lines of making a different user interface. Maybe hooking it up to a joystick....
Unread 06-01-2008, 23:46
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
hooking it up to a joystick, while workable, would be very jerky and hard to control, seeing as it would only have one speed and would only receive a signal every 1/10th of a second.
I know that my team was looking into making our own IR transmitter, we rigged something up today using a AVR (i believe) along with a little code, and it worked great
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 06-01-2008, 23:53
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
That's cool. I was concerned that we would have to hit that 38KHz or something band for the red IR board to be able to pick up our signals. What kind of signals were you using (how many bits, what frequency, etc)?
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 07-01-2008, 00:17
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
If you look at <R65> (which is a bit too long to post here), it implies that not only can you build your own signaling device (it even gives maximum dimentions), but you could also design or hack your own receiver! The restrictions are communication method - Visible or Infrared light, or Sound, and that it only receive/respond to 4 states.
Steve
Vex Transmitter sale. Gdeaver VEX 2 11-02-2007 21:01
Vex Transmitter problem TheOtherGuy FIRST Tech Challenge 3 21-07-2006 17:01
transmitter question??? mechanicalbrain Control System 1 23-04-2005 16:55
FM radio transmitter Alexander McGee Electrical 11 29-10-2003 19:41
