Go to Post What has happened has happened. Humans were involved, mistakes made. Clarification will come... - Wetzel [more]
Unread 07-01-2008, 16:18
daftpunk79's Avatar
daftpunk79 daftpunk79 is offline
AKA: Lizzy
no team (Bomb Squad)
daftpunk79 is on a distinguished road
Send a message via MSN to daftpunk79 Send a message via Yahoo to daftpunk79
Here's a tip....
I've been in track, and I've learned that when you are running a race, stay on the inside of the track.
So therefor, stay as close to the lane divider as much as possible...you go around faster and you have more time to make more laps.
Unread 07-01-2008, 16:19
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Here's a tip....
Presuming your turn radius is near 0.
(since 2004)
Unread 07-01-2008, 16:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
So... just how small of robot are you willing to build to be able to accomplish near 0 turn radius?
Unread 07-01-2008, 16:26
daftpunk79's Avatar
AKA: Lizzy
it was only a tip and i said stay as close as possible not so close you cant do anything.
Unread 07-01-2008, 17:13
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
It's a good tip if you're going for just a quick 2 points by racing around the track.
But if you're hurdling or herding a trackball, you'll need to stay a bit on the outside to compensate for certain factors. Also if you're hurdling you need to factor in the time and space to collapse something like an arm if when extended to hurdle it goes past 6'.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 07-01-2008, 17:16
flightofone flightofone is offline
AKA: John Clayton
FRC #2104 (Colonel Robotics)
flightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really nice
Send a message via AIM to flightofone
The problem is not as simple as taking the least distance. If the object is to minimize the time around the track, you will need to determine the entry and exit points of the turns that maximize your acceleration into the straightaway.
There's a fine line between fishing and just standing on the shore like an idiot. - Stephen Wright
________________________________________
2007 UTC Regional - Finalists (thanks 25 & 176)
Unread 08-01-2008, 22:59
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Also I'm not sure how the lane divider will be anchored. Considering that you can't bolt onto the field it will most likely need a platform underneath for support. Based on the field set-up at our remote kickoff there the platform sticks into the field atleast a foot. I would assume that FIRST would make the platform out of something thin like aluminum but this may still be a driving hazard to some teams.
Unread 08-01-2008, 23:01
There will be plates underneath. They are about 1/4" thick and create a 1/2" bump. See Section 6.2.3.
A Tip for the PDB Pavan Dave Electrical 4 06-01-2008 22:20
TEAM TIP: Holiday Food Drive! Rich Wong General Forum 0 20-11-2003 01:30
2003 Robot Machining Tip Matt Reiland Technical Discussion 1 14-11-2002 12:54
I tip my hat to all rookie teams archiver 2001 2 24-06-2002 02:25
Web Site Update Tip archiver 1999 0 23-06-2002 22:37
