Go to Post Smells like gracious professionalism in here... :) - marshall [more]
Unread 08-01-2008, 12:58
Katusha's Avatar
Katusha Katusha is offline
Vice President Team 168
AKA: Katya Sorsher
FRC #0168 (M.I.B.)
Katusha is an unknown quantity at this point
Send a message via AIM to Katusha
Exclamation Driving in Reverse???
How far can we go back wards with out getting a penalty? Our team is trying to get all the calculations down for an arm but if we're trying to hurdle the ball and we drive back a little to reposition will we be penalized?
-Katya
Team 168!!!
Unread 08-01-2008, 13:06
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Driving in Reverse???
You can go back (clockwise) as much as you wish.
You will be penalized if you are to cross any line (finish or lane marker) thereofre, you can stay in a selected 1/4 of a field without getting penalized.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2008, 13:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Do you have a rule that specifically quotes that?
Unread 08-01-2008, 13:23
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Lightbulb Re: Driving in Reverse???
<G22>Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
My interpretation of this is you are only penalized when you break the plane of the quadrant located "behind" you (considering forward to be the counter-clockwise direction). From this one may infer that a robot is able to move freely within any given quadrant as long as you don't break the plane of the previous quadrant.
<edit>
Also, <G23> takes care of the "what if I was pushed into the previous quadrant" question. You cannot be pushed into a penalty. If you are pushed, the penalty is excused.
<G23>Causing PENALTIES - A ROBOT’s action shall not cause an opposing ROBOT to break a rule and thus incur penalties. Any rule violations committed by the affected ROBOT shall be excused, and no penalties will be assigned. For example, an opposing ROBOT may not be pushed into another ROBOT in an attempt to cause a IMPEDING situation and violation of Rule <G40> by the opponent, nor may a TRACKBALL be placed intentionally on an opposing ROBOT for the purpose of causing the opponent to violate Rule <G26>.
</edit>
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 08-01-2008, 13:53
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
<edit>
</edit>
It is just that, your interpretation. If you read the rule:
The red emphasis is mine. It states clearly at the beginning that the rule is about direction of travel and then states the direction. It then goes on to clarify that you cannot go back and forth over the line to score. It then states that there will be penalties. There is nowhere in the rules that it says that you can travel in a clockwise direction for any reason.
I can see your point but we have always asked FIRST to clarify certain things and when they do then we question them. The only way to know the real answer is to ask the GDC. Remember the safety issue and the effects of collision if we get robots going backwards.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 08-01-2008, 13:56
Tottanka's Avatar
AKA: Liron Gurvitz
There is also nowhere in the rules that it says that you can't.
Unread 08-01-2008, 14:00
SuperJake's Avatar
No Problem!
AKA: Jake Classic
Isn't that inferred by <G22> stating "ROBOTS must proceed around the TRACK in a counter-clockwise direction."?
Unread 08-01-2008, 14:03
Tottanka's Avatar
AKA: Liron Gurvitz
But then it mentions that it means not to cross lines in a clockwise direction. Your direction of movement will be difened not by the location of your robot, but by when you cross which line.
Unread 08-01-2008, 14:05
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
"Proceed" doesn't necessarily mean "always move".
It could mean that you just must make your progression around the track (quadrants) in the counter-clockwise direction.
Unread 08-01-2008, 14:02
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
How about this !
Moving backward and driving backward is different, right ?
What if you drive forward across your start/finish line, and drive backward over the other start/finish line.
The CG of the object is moving counter clockwise, but the robot is tank drive forward, then backward, then forward, etc.
Just to be clear it is forward in you lane, backward in the other lane, but the CG is counterclockwise ?
Eh ?
Ed Barker
Unread 08-01-2008, 14:04
Tottanka's Avatar
AKA: Liron Gurvitz
Originally Posted by ebarker View Post
How about this !
Eh ?
YES!
Ginnaly someone ehre mentions my idea for this game!
those are exactly my thought of the best drivig system for this year.
Grow Up? Why?
How about this !
Eh ?
As the RULE states : ROBOTS must proceed around the TRACK in a counter-clockwise direction
There is no mention of the way the robot points, just the direction of travel based on the field layout.
Unread 08-01-2008, 14:40
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
then there is another rule (i dont have a manual handy cuz im in my house sorry no quote) that says that you must cross the opponents finish line before you cross your own
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 08-01-2008, 16:50
Katusha's Avatar
AKA: Katya Sorsher
FRC #0168 (M.I.B.)
Unhappy Re: Driving in Reverse???
Guys we mean like if you place the ball over the over pass but then have to back up to get your arm mechanism from over the overpass. will they really penalize us for that? I mean we're not allowed to get caught on any field elements so whats the answer?
-Katya
Team 168!!!
Unread 08-01-2008, 17:04
No penalty. You haven't crossed the finish line yet, so no penalty there, and you probably won't need to go clear back to break the plane of the lane marker, so no penalty there.
Reverse Ramps??????? cardinalman86 Programming 3 18-02-2007 18:25
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Reverse Robotics !!!!!!!!!! dan 322 General Forum 42 25-04-2004 00:44
Chiaphua in reverse?? Christina Motors 2 09-01-2002 08:40
