Small robots in 2008
How many teams have toyed around with the idea of making the smallest robot you can with the required components?
These can be advantagous as far as just running laps if you don't want to hurdle balls. I'm predicting we will see some 1' x 1' robots who's mission is to just to race around the track doing laps and gaining those points as fast as they can. Hopefully designers of these robots will at the very least take the time to protect themselves from a 10lb ball dropping on them from 7+ feet. ![]() |
Re: Small robots in 2008
We discussed it in our strategy meetings. We're not going to do it, but we definitely brought it up as an idea.
Any team planning on hurdling will probably want to have a robot with a large base (for stability), and herding on the floor might also require a larger base. If you're planning on just driving around, though, I could see a definite advantage to having a small frame, to make it easier to slip through small gaps. |
So as long as there is enough room on the robot for such necessities like a battery and control system!
I think a 1'x1' robot might be at a disadvantage due to the flag holder rule (can't recall which number right now). A 1'x1' robot that has a roughly 5' pole on it to support the flag would be a good candidate to flip as the much larger robots and balls are flying around.
I had fun with the idea in my head. The team agrees some team is going to make a dedicated lap running robot, and personally, if there is a team gutsy enough to do it, I would LOVE to see it happen.
That big battery is a great counter weight. Even with a flag pole made out of steel I don’t think it would be a problem |
#7
We have tinkered with the idea of using a similar design to our "mini-me" robot from last year. If you were at the CO regional we were the little bot that looked similar to your kitchen sink. Very fast and maneuverable
#8
The required bumper rule kinda puts a twist on the concept too. A 1'x1' chassis almost becomes a 2'x2' because of the required bumpers.
#9
The flag pole would be a bigger worry in that it would provide a great lever for a trackball or other robot to tip your robot over with.
#10
ok, im weird i gues, i think it would be kinda cute to see a little robot zipping around the track as fast as possible.
#11
One lap only gets you 2 points. So, other than a rookie team, this seems like a fruitless strategy.
#12
2pts in Teleoperated mode. But... in just 1 lap of Hybrid mode, a small, very manuverable, quick robot can go wayyyy past 2 points a lap. Just how many? We'll see... depending on how the rules are clarified in the next few weeks will determine that. Quote:
#13
Additionally, this year assuming you get 2 hurdlers, or even a good hurdler and a good herder, I seriously the doubt the alliance selection field would be deep enough at any event save the championship to field another good ball handling robot on your alliance. Thus, a super fast controllable mini racer is looking like a pretty darn good choice for that 3rd robot. ![]() |
#14
Isn't there a rule saying that the longest dimension of the robot needs to be vertical when starting the game? Let me see...
the rule states that hour longest (maximum) dimension must be vertical. I interpreted this to mean that your foot print at the start of the match can not be greater than 28x38, but there is no limit to how small it can be as long as you don't start the robot to have the 5' dimension horizontal.
| 2008 Offseason event MARC being moved to JUNE 28, 2008 | Steve Ketron | Off-Season Events | 10 | 21-03-2008 07:55 |
| [Official 2008 Game Design] OK, so YOU design the 2008 game... | dlavery | FRC Game Design | 25 | 20-02-2008 23:31 |
| Are FIRST robots actually robots? | EHaskins | General Forum | 39 | 14-12-2006 21:40 |
| Robots and Small Balls | archiver | 2001 | 6 | 24-06-2002 00:44 |
| Small Parts | archiver | 2000 | 2 | 23-06-2002 23:09 |
