Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 09-01-2008, 12:25
Pelicano234's Avatar
Pelicano234 Pelicano234 is offline
"Glish"
FRC #2077 (Lasers)
Team Role: Student
Pelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nice
Circle base vs. Rectangle base
We have decided that we are going to try to hurdle the ball. Our biggest disscusion right now is whether to have a 28x28 circle base, or a 28x38 ractangle. What do you guys think?
Unread 09-01-2008, 13:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Cricle base vs. Rectangle base
It would probably be a little difficult to cover at least 2/3 of a circle base with bumpers...
Art Dutra IV
世上无难事,只怕有心人.
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Depending on what wheels you use, a circular base may/may not be moved around more than a rectangular base. In general, I'd think that a rectangular base would be more sturdy, but that could just be an opinion. However, welding and cutting a circular base would surely provide a significant problem, unless you are associated with a metal fabrication shop. But other than that, there's really not much difference (that I can see). A circular design or two would certainly add some variety to the competition.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 09-01-2008, 13:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The further apart the wheels are, the less likely the robot is to tip over...and handling that big ball might cause problems with this.
A round robot probably has the wheels closer together than a rectangular one.
Unread 09-01-2008, 16:28
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
What advantage do you think a circular base will give you? What disadvantages do you think it will give you?
Have you considered other shapes? Perhaps a triangular or hexagonal base? I would think that a circular base would be harder to manufacture, due to not having straight lines. Another shape, like a hexagon, might give you a close-enough approximation to a circle to gain whatever advantage you expect to get from a circular base, while still being relatively easy to cut pieces for.
Personally, I think that since most robots will be rectangles of approximately the same dimensions, it would be nice to see some variety out there. I recall seeing one robot a few years ago (2002?), which was based on a triangular base. It had three wheels, 120 degrees apart from each other, and functioned as an omni-drive. I've heard of another similar drive which, in 2003, drove and turned so fast it would bank up on only 2 wheels.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 12-01-2008, 17:07
Josh363663 Josh363663 is offline
AKA: JOSH FARROW
FRC #1529 (Cyber cards)
Josh363663 can only hope to improve
ideally fewer wheels are better in that you are less likely to get caught in corners
Unread 13-01-2008, 00:20
BK Lounge's Avatar
BK Lounge BK Lounge is offline
Brian Kyte
AKA: BK Lounge
FRC #1591 (Greece Gladiators)
Team Role: Driver
BK Lounge is an unknown quantity at this point
Send a message via AIM to BK Lounge
It all depends on your manipulator. How big is it going to be? How much surface area will it take up? circular bases tend to have less area to work with. However circular bases can turn quicker. Rectangular bases have more surface area and i my opinion are easier to work with.
nuts hold the world together, the world holds us, i hope we didnt forget to tighten them nuts
Unread 13-01-2008, 00:31
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
I don't think a round base would be very good unless you had a lot of excess weight, if it exists, and can put a few heavy blocks in the center to keep a good center of gravity and lower weight. you could also lower the base a little too, just to help u from tipping over. in this competition, it doesn't give you much of an advantage. if ur stuck on a circle design, but can't fabricate it, why not try an octagon, it will make it a little bit easier and allow for the same minute advantages as well.
I personally kinda like the square base design, but only cus it allows for so many wheel options. if u do it year after year it gets a little boring, so u can round the corners or random stuff like that, but it's probably the way to go.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 13-01-2008, 00:38
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
one nice advantage of having a circular base is that in a game where one's ability to maneuver in traffic will be at a premium, never getting caught on someone's corner and the ability to always turn in place, regardless of what's nearby could come in handy.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 13-01-2008, 07:06
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
You cannot have a perfectly circular base. You can have an n-sided polygon that approximates a circle. This is because of the mandatory bumper rule. Bumper pieces must be at least 6" long, and must be backed by 3/4" plywood. So unless you can find some circular plywood ...
(since 2004)
Unread 13-01-2008, 08:07
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
A company that I used to work for made curved panels for office cubical dividers all the time. Given the concern over the eighty inch max. dimention I could easly see where a curved bumper designed so that the outer edge of the noodles is curved at the same arc as the 80" circle could become a possible solution. It would be rather easy to sandwich 1/2 plywood with grooves cut into it between outer skins of 1/8" of whatever wood product you chose.
"STANDARD BUMPERS must be designed as shown in figures 8-1 and 8-2. This is the only acceptable design for STANDARD BUMPERS".
Looking at the quote above, figure 8-2 shows only straight bumpers. If anyone decides to construct curved bumpers I would suggest getting a Q and A answer. My guess would be that the GDC would reply with a statement along the line of: Please refer to Rule R-8 for the ONLY ACCEPTABLE design. Making curved bumpers illegal, not impossible to construct.
Unread 14-01-2008, 20:52
cobrawanabe1699's Avatar
cobrawanabe1699 cobrawanabe1699 is offline
That kid with the TIG welder
AKA: Matt, or to those in the northeast, THE BOBCAT!!!
FRC #1699 (ROBOCATS)
cobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the rough
Boy, oh BOY is that round base alot bigger of a bite that what you may realize. I'm not sure of the size/experience of your team, but I think that you may be biting off more than you can chew. Your team MUST have machines (CNCs, mills, etc) that are capable of machining perfect circles (no matter how skilled you are with a dremel, it will NEVER happen hahahaha). Also, the bumpers will have to be curled in a perfect circle (and I dont think an English wheel will work too well with that, as it put a more spherical curve in parts). But hey, if you guys can do it, you will have my absolute amiration. GOOD LUCK!!!
BOBCAT OWNS
I done welded me a robot!
TECHNICAL JUDGE:
FLL Bash @ The Beach 2007 Regional Competition
FLL State Championship, CCSU 2007
FLL Bash @ The Beach 2008 Regional Competition
ATTENDING IN 2009:
FIRST Kickoff in NH
FIRST Regional Competition: Washington DC
FIRST World Championships: Atlanta, Georgia
"If it ain't broke, fix it 'till it is."
Unread 15-01-2008, 16:08
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Re: Circle base vs. Rectangle base
I'm on the same team, and yes, I think one of our sponsors can help us with bending the metal. However, I think we have dumped the circular base. It would really only be good for a bot whose only job is to run around and score points that way.
But having a circle bot would look awesome, wouldn't it
Unread 15-01-2008, 16:49
Its not the bending that would give you the trouble. That would be NOTHING compared to the geometry and CUTTING involved with a circular base.
BOBCAT OWNS
TECHNICAL JUDGE:
ATTENDING IN 2009:
FIRST Kickoff in NH
pic: Entire base Redo91 Robot Showcase 4 17-02-2007 12:24
Knowledge Base Leon Machado IV Programming 15 02-08-2005 12:24
Delphi Base archiver 1999 0 23-06-2002 22:03
