Go to Post This could be interesting...rednecks of FIRST unite for duct tape - amos229 [more]
Unread 10-01-2008, 12:59
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
pneumatic air sping
Can I pressurize a cylinder with the max 60psi, then compress the cylinder mechanically and release it to create an air spring?
<R98> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must be provided through the Norgen adjustable pressure regulator, and all other pneumatic components must be downstream from this regulator. A pressure gauge must be placed adjacent to the pressure regulator and display the downstream pressure.
I supply the working air through the Norgren at 60psi.....mechanically compressing the cylinder will increase the pressure, but it doesn't seem to violate the pneumatics guidelines.
What do you think?
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 10-01-2008, 13:02
Gdeaver Gdeaver is online now
FRC #1640
Re: pneumatic air sping
I believe the regulator is the relieving type so that if the pressure goes above 60 PSI it will relieve to mantain 60 PSI. For saftey no component should be capable of going above 60 PSI.
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Pneumatic Air Tanks supertw Pneumatics 3 10-02-2005 02:51
Pneumatic Air Tanks supertw Technical Discussion 3 10-02-2005 02:51
Air Tanks geo Pneumatics 8 25-03-2002 15:13
Air Tanks geo General Forum 2 07-02-2002 19:30
