Go to Post I don't think it's that big of a deal if FIRST makes a few mistakes or cuts back every now and then. Personally, I'm just glad I have the opportunity to be in this program. - Crop-Circles [more]
Unread 12-01-2008, 11:27
Demothesis's Avatar
Demothesis Demothesis is offline
Team Leader/Programmer
FRC #2169 (KING TeC)
Demothesis is on a distinguished road
RPM under load
What is the RPM of the CIM motors under load?
I know that the loads will be different, but could you give it to me under peak load?
Demothesis
Unread 12-01-2008, 22:30
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: RPM under load
FIRST Guidelines, Tips, and Good Practices page 5 has a table with all the CIM speeds. The term "peak load" is kind of ambiguous, you should probably go for "design load", which is shown as "normal load" in that table as 4320 RPM. But before you run off and determine robot speed based on that, remember that the motor could care less what speed you want it to run at; it is going to run at the speed that corresponds to the load (torque) demand you put on it. You design to an applied load and the speed is a fall out, not the other way around.
**FIRST EMAIL**/Championship Updates - Load In and Load Out and Finale Ticket Inform AmyPrib FIRST E-Mail Blast Archive 3 21-04-2006 11:08
RPM Sensing Options schenkin Programming 12 28-01-2006 21:13
Drill RPM Jonathan Motors 2 06-02-2004 21:00
Motor rpm and Torque D. Gregory Motors 41 12-01-2003 10:56
Last Years RPM Brett W Technical Discussion 18 04-12-2002 21:04
