Go to Post Note: Please don't actually mob them or cause them any harm. It's just a saying people. :) - CalTran [more]
Unread 12-01-2008, 12:07
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
Can we use Servo Hitec#HSR-5995TG
I read in the rules they have a limited number of motors listed that we could use. we were wondering if we can use this servo for some stuff. I am leaning towards no from what I have read but just wanted to confirm it here.
http://www.hobbyhorse.com/hitec_hsr5995tg.shtml
Thanks in advance.
Unread 12-01-2008, 12:23
Re: Can we use Servo Hitec#HSR-5995TG
Thanks in advance.
No. If you read Section 8.3.7, you will find motor/servo restrictions. If you read <R59> in that section, the HITEC HS-322HD servos are the only ones (other than VEX) that you are allowed to use. (And the same rule lists the only other allowed motors, as well.) <R60> bans all non-kit, non-<R59> motors and actuators.
Unread 12-01-2008, 12:32
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Here is the full text of the rules quoted above:
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
• All motors, actuators, and servos provided in the 2008 Kit Of Parts,
• HITEC HS-322HD servos,
• FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
• FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
• One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
<R60> Items specifically PROHIBITED from use on the ROBOT include:
• Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R59>.
• Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
That is it for electric motors, servos, solenoids...
That leaves you to consider pneumatic devices which are also restricted to specific devices in the rules.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
servo PWM sampling-what Fosc should I use? 3dude_2231 Technical Discussion 6 23-08-2007 13:17
[FVC]: Can you change a vex servo to motor? Marcel FIRST Tech Challenge 6 02-02-2007 14:41
Trying to use a new servo team1500 Electrical 1 20-02-2006 21:27
Did you use Auto Servo Mode? Greg Marra Programming 8 27-04-2005 15:35
2002 Kit Hitec Servo Part Number kmcclary Motors 6 03-12-2002 11:49
