Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
Unread 13-01-2008, 15:10
C222's Avatar
C222 C222 is offline
Computer Science Major
FRC #0852 (Athenian Robotics Collective)
C222 is on a distinguished road
Another IR Board Problem
So, my team has had some problems with our IR board. We had to replace the voltage regulator, went through 4 remotes that didn't work. now we have a remote that seems to work, however, when the board switches out of learn mode the LEDs don't light up when we send the commands to the board again.
help... please.
Edit: every time we reboot the board after learning the error light comes on for about 1 second.
Unread 13-01-2008, 17:05
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Another IR Board Problem
This is really similar to what is happening to us.
At first our IR sensor was hooked up to a prototype board and it worked well. It was receiving signals from the remote control and everything.
But then, in the course of hooking it up to our test bot, we reversed the pwms, mistakenly plugging the white signal wire into the ground on the digital in/out section.
Since then our board will train perfectly, but when we send a signal after training it, it just blinks an error light repeatedly until we power down.
We checked our 5 volt regulator and it is functioning just fine, and we never smelled any smoke. We also tried two different remotes which each worked when we had the IR Sensor hooked up to our original prototype board. When even rehooked the sensor up to its original prototype board, but it still doesn't work.
I don't have any idea on how to fix this problem, anyone else have any ideas?
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 13-01-2008, 17:36
If you have killed the five volt regulator, then I always suspect the parts connected to it. The board is talking to you. Although you think it has learned the commands it is telling you it has not.
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Problem solved but now another question Adam Y. Programming 1 03-05-2006 08:54
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
121, another competition, another victory. Greg Perkins Off-Season Events 27 06-06-2002 23:13
