Go to Post TL, DR: You may be skilled at karate on your own, but imagine how much better you'll be with Mr. Miyagi mentoring you. - artdutra04 [more]
Unread 13-01-2008, 21:14
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Issues with our code
We're moving to WPILib this year and are having a few issues getting our code working with the FRC controller. We tested it out quite a bit on the Vex robots last fall and it worked great, but we tried downloading to last year's FRC bot for the first time today and couldn't get it to work.
The code below compiles and downloads, but does nothing after that. We were trying to get basic drive working first with the Tank2 function (We have one CIM motor on each side, plugged into PWM ports 13 and 15). Then we commented out the Tank2 function to see if we could just get the motors to turn on at all with the SetPWM function, and that didn't work either. Any ideas what we're doing wrong?
We are using MPLab v8.00, the C18 Compiler v2.40, and IFILoader v1.10.
#include "BuiltIns.h"
void IO_Initialization(void) {
	SetCompetitionMode(1);
void Initialize(void) {
	DefineControllerIO(INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT,
					   INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT, INPUT);
void Autonomous(void) {
	printf("Autonomous\r");
	while(1) {
		printf("In Autonomous\r");
		SetPWM(13, 50);
		SetPWM(15, 50);
void OperatorControl(void) {
	printf("OperatorControl\r");
	while(1) {
		printf("In OperatorControl\r");
		SetPWM(13, 50);
		SetPWM(15, 50);
		//Tank2(1, Y_AXIS, 2, Y_AXIS, 13, 15, 0, 1);
void main(void){
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 13-01-2008, 21:19
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Issues with our code
Do you have your robot enabled on the operator interface? (done that WAY too many times)
Otherwise looks good. Are you getting your printf text?
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 13-01-2008, 21:24
Engineering Mentor
Yes, our robot was not disabled, but we have make that mistake before too
We tried it both with and without the autonomous switch on and it didn't work either way.
And, the printf's do work. They run continuously, inside our while(1) loops. It prints "In Autonomous" when the our auto switch is on, and prints "In OperatorControl" when the auto switch is off.
Unread 13-01-2008, 21:28
FRC #0240 (TEMPEST)
Are you sure it's not a physical problem?
i.e. are the fuses in, do the victors light up when the program is running, are your pwms plugged in all the way, do you have a fully charged battery?
I know, probably not your mistake, but I can't see anything wrong with the code.
Unread 13-01-2008, 21:31
Engineering Mentor
Well, the Victors are flashing orange, so they're not getting any signal at all. Does WPILib initialize all the pwm's to zero like the default code does? Should these be getting any signal?
We also tried loading our code from last year (default FRC code) and it worked fine, so I'm thinking it's not a hardware problem.
Unread 17-01-2008, 18:58
btgdaniel's Avatar
btgdaniel btgdaniel is offline
FRC #1731 (Fresta Valley Robotics)
btgdaniel is an unknown quantity at this point
Question Re: Issues with our code
Did you ever get WPIlib to work? We are having the *exact* same problem. No outputs to PWMs, last year's code works fine. A little more info: (1) joystick input seems to work; (2) analog input works.
Team 1731
Catch the FeVeR ~ If You Can!
Unread 17-01-2008, 19:07
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
We've been having the same problem. Using WPI Lib, we cannot get any output on PWMs 13-16. We tried using the SetPWM() function, along with Motor(), Motors() and Drive(), all to no effect. We also tried using WPI Lib with the IFI header files and setting the PWMs using the aliases from ifi_aliases.h, and again 13-16 are non-responsive. When using the default IFI code by itself, we can control them just fine.
Which badges can you claim?
Unread 18-01-2008, 03:03
Engineering Mentor
Well, I'm not exactly sure what we did, but it is working now. Unfortunately, I don't know exactly what fixed it, but here's a few things to check:
Download the latest firmware to the RC, which can be found here:
http://www.ifirobotics.com/docs/frc-master-ver15.zip
Try tethering to the OI at least once first.
The OI needs to be on and communicating properly for the RC to output to anything.
Make sure you have your backup battery plugged in.
Unread 18-01-2008, 10:55
AKA: Brad
#0190 ( Gompei and the Herd)
There are issues with the PWM ports 13-16 since they are controller by the user processor. Try the program with ports 1-12 instead. I think the motors will start working.
Brad
Brad Miller
Robotics Resource Center
Unread 18-01-2008, 11:15
Engineering Mentor
That actually makes a lot of sense now! We got our code working on our new RC (using PWM 1&2), but the old one wasn't working (using PWM 13&15). We didn't originally change the old RC ports because on last year's robot it is very difficult to access and requires unscrewing a lot of electronic components. We're planning on making this year's much easier to access.
Does this mean that we will be limited to 12 PWM ports if we use WPILib? Or is there any way to use 13-16? Right now we're only planning on using 10 PWM ports, so we should be okay, but would we have room to expand to more than 12 ports?
Last edited by Richard McClellan : 18-01-2008 at 11:21. Reason: added second paragraph
Unread 19-01-2008, 10:07
AKA: Brad
Kevin Watson wrote some code last year that allowed control of the extra PWMs in your user program. It works with easyC and WPILib and can be integrated easily into an existing program. You can find the explanation here.
Brad Miller
Unread 19-01-2008, 15:14
btgdaniel's Avatar
Thanks, Brad! That new pwm code fixed it! PWM's 13-16 are now good.
Team 1731
EasyC master code issues Joe G. Programming 2 14-12-2007 11:28
Code Flashing Issues bluenp Programming 4 07-11-2007 23:43
need help with our default code coolguybigt Programming 14 19-02-2007 10:17
Issues with encoder code jgannon Programming 7 26-03-2006 15:12
Issues with MPLAB 7.30 gnirts Programming 4 25-01-2006 22:57
