Needed Cylinder Math
Hi there, we did the following math and I would like to check it over because it seems a bit fishy:
We are using: 21.5" 1" PVC tube where the axis of rotation is about 1.5" from one end we believe that it is about 1 lbs total. On that axle there will be a sprocket which we currently have at 5" diameter. We plan to have the piston connected by chain to the sprocket to make a 90 degree rotation. What size sprocket/piston do we need, what pressure? We calculated that we would need a 1.5" bore piston with a 4 inch stoke at 40 PSI to have a balance (No safety factor at 40psi, up to 60psi would be our safety here), is this all correct? Last edited by Lawry Goldstein : 15-01-2008 at 17:11. Reason: Bad Spelling - :-( |
Re: Needed Cylinder Math
Math sounds about right. The only thing that sounds a bit off might be the pressure but if you get a regulator you can regulate it down to whatever works the best. I'm assuming that the 4 inch throw is from a 5inch sprockets circumference of about 16 inches of that and a fourth of that is 4 inches. if thats so then thats all the throw you need.
| Math in careers | EricH | Career | 40 | 24-06-2008 21:45 |
| Tetra Math | ZZII 527 | General Forum | 34 | 22-01-2005 14:13 |
| A math haiku | mtrawls | Chit-Chat | 0 | 11-03-2004 20:22 |
| math.h library | mightywombat | Programming | 24 | 17-01-2004 13:10 |
| Math | Hermione692 | Chit-Chat | 15 | 21-02-2003 10:47 |
