Go to Post FIRST isn't only about winning, it is about making friends, gracious professionalism, and having fun. - lallamavolador [more]
Unread 15-01-2008, 22:38
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
EasyC Copy & Paste
If a function is written within EasyC using the drag & drop coding blocks. Is there any way to copy the code within that function to another function so that you can modify it for a slightly different use? Or can you copy the whole function and give it a different name?
Unread 16-01-2008, 10:41
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: EasyC Copy & Paste
You can do both.
1.) Right click on your function can click copy function easyC will ask for a new function name.
2.) You can copy multiple blocks using shift / control just like any other windows app
Unread 16-01-2008, 12:57
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
How about this.
Three programmers. Each with is own copy of EasyC. Each programmer working on a Function, and one MASTER CODE.
Can we copy and paste a function from programmer #1 EasyC file to the MASTER CODE EasyC file?
We tried running two instances of EasyC on the same laptop, and copy between the two applications, but that does not work....
We have "teams" of programmers and it's hard to share with each other, with out recoding the entire function in the MASTER COPY...
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 22-01-2008, 23:52
I don't have a copy of the software handy at the moment, so forgive any minor inaccuracies in what I'm about to say.
When you right-click on the user functions, you get two options. One is to make a new function. The other is to copy an existing function from another project. I think that does what you want.
(You apparently can't copy the Initialize or Autonomous or OperatorControl functions, but a bit of creative copy & paste in both the source and target projects can work around that restriction.)
Unread 24-01-2008, 09:21
Controls Engineer
AKA: chakorules
Why didn't I ever notice that before...that will work for what I am doing. It does not import variables...that's a good thing and a bad thing, but I'll take it! Saves alot of time reconstructing the EasyC Blocks.
I see that if somehow I export a function in another project as a library file, I can then attach with it, macros, variables, and code. That might be the way to go to move massive amounts of functions around from team member to team member.
Favorite CD quote:
Unread 24-01-2008, 15:10
Kingofl337's Avatar
AKA: Adam
If you save a project as a library it will import variables.
Unread 24-01-2008, 16:48
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
You could use the approach we are using this year. We have a total of 6 programmers each working on their own seperate parts of the code. To get around this, we have a "master program" which is just made up of seperate functions (in operator control, two functions are used, operator drive and operator arm for ex.) Each person works on their own seperate function, ex, I work on operator arm. I make any variables I use local variables, and when we import the function into the master code, outside of rewriting a couple of constants under the global category, it is pretty much copy and play.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
Copy and Paste Rules Yan Wang Rules/Strategy 2 13-01-2006 16:04
pic: #1213 Undo Copy Paste CD47-Bot Robot Showcase 1 14-02-2004 18:37
