Go to Post They have a Woodie Flowers Finalist, Outstanding Volunteer and numerous UFH Awards to demonstrate this as well. You do not receive any of these accolades without doing something right. - J Flex 188 [more]
Unread 16-01-2008, 15:06
Never_Fade's Avatar
Never_Fade Never_Fade is offline
Sub-Programmer
AKA: Michael Brown
FRC #0842 (Falcon Robotics)
Never_Fade is an unknown quantity at this point
Send a message via MSN to Never_Fade Send a message via Yahoo to Never_Fade
Where to connect the backup battery charger
We have a question about the backup battery charger (Found here).
We are curious if we are supposed to connect the 12v in(of the charger) before the master breaker, or after the master breaker.
http://picasaweb.google.com/KE7CKI/Robotics/photo#5156166962017891010
We have it hooked up on this side. Can we hook it up here?
We currently have the 12v in connected after the master breaker (on the 20/30 fuse panel), the 'backup battery input on RC unit' connected to the battery input on the RC, and 'backup battery' label on the diagram connected to the backup battery.
Our situation occurs here. When we do not have the main 12v battery powered up, the 7.5v backup powers the system, through its connection on the 20/30 fuse panel.
If we were to connect the battery charger in the line before the master breaker, the 12v battery could be in -charging our 7.5 backup- while the breaker was restricting power to the rest of the robot. We are under the impression that this is illegal because that means that there is power running while the breaker is off (which defeats it's purpose, in a sense).
Unread 16-01-2008, 19:52
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: Where to connect the backup battery charger
I don't know that is a good question....!?
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 16-01-2008, 23:03
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Why not just throw some spaid connectors on there and run it through the fuse panel?
Unread 16-01-2008, 23:42
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
We have used the IFI circuit for 2 years now and have noticed the partial feedback issue. No inspector or referee has complained yet. It isn't an optimal design. but it will drain your backup battery if allowed to continue.
This year FIRST alloes custom charging ckts. If 'not happy, Draw
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 16-01-2008, 23:47
falconmaster's Avatar
Happy Birthday! falconmaster falconmaster is offline
AKA: Ledge
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Are you sure that this year we can use our own charging circuit?!!!! Where do you see that?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2008, 23:51
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Sounds like it... check this out.
<R49> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with a 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. or any similar charging circuit (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-01-2008, 23:54
It's a custom circuit. It has to be powered from a 20A circuit breaker.
To address the problem with back-feeding the rest of the robot, just add another 1N5820TR diode in series with the power input. You might still see a small issue with the backup battery draining (slowly) through the charger circuit itself when the robot is powered off, but it will no longer try to run all the Victors.
Alternate Backup Battery Charger Phalanx Electrical 5 24-02-2007 14:51
Powering the cam without a backup battery Uberbots Programming 11 27-01-2006 10:00
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
how do u connect the battery to the robot interface? chrisw Technical Discussion 1 10-01-2002 16:41
