Kevlar Honeycomb
Does anyone know how tough kevlar honeycomb really is, any do you think it could help protect your robot this year?
Re: Kevlar Honeycomb
isnt there a thread on this?
Yes...and no. The other thread was asking "Can it be used?". This thread is, "Is it strong enough?"
The answer: I don't know. I've never played around much with honeycomb materials. I do know that corrugated plastic is plenty strong in the right place, as is lexan. |
I was looking at the web and thought this might help.
http://www.plascore.com/honeycomb/pa...-honeycomb.asp |
Some of that stuff is made to stop a person traveling at terminal velocity. So it depends on what you have.
That stuff is killer strong....we were considering using it for our ramp platforms last year.
#7
How do you cut it or otherwise shape and work with it?
#8
The honeycomb itself isn't very strong, but is combined as a core in a sandwich with FRPs like fiberglass, kevlar or carbon fiber cloth outer layers. That produces about the strongest, lightest construction possible. There are a number of practical problems with actually making the panels, including epoxy resin toxicity, cutting it (there are special shears), avoiding having the core material soak up the resin (pre-preg with approriate films works for this), avoiding voids (vacuum bagging), and heat curing.
If you are just thinking about it now, you may want to buy pre-fabricated panel material or use aluminum, as there is a steep learning curve to the fabrication. Nomex is another popular core material - slightly less expensive than Kevlar honeycomb. It makes a great off-season activity to build up the expertise. |
| Is Kevlar Honeycomb allowed? | jleung | Rules/Strategy | 23 | 17-01-2008 17:25 |
| NEED: carbon fiber/kevlar/composite I-beam | Gabe15 | General Forum | 2 | 10-01-2008 08:44 |
| aluimium honeycomb panels | Matt21q | General Forum | 1 | 03-02-2007 11:45 |
