Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 17-01-2008, 15:34
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Dimensioning Lofts
Ok, this is kinda off season stuff, but it is trouble we are having in class and are more or less just wandering if there is a way to do it.
We are working on making bottles for a project in our Inventor class and I just so happened to make it using a loft. I asked my teacher how we could dimension the curves, but he couldn't figure it out either.
does anyone have a solution on how to dimension the curves on the side of a loft?
Seth
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 17-01-2008, 15:55
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Dimensioning Lofts
I would think about doing section views showing the shapes that make up the loft, and dimensioning them.
Hi!
Unread 18-01-2008, 09:23
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Section views are definitely the answer. Though, I might go about it in a different way. Instead of doing several section views of the shapes, consider doing one vertically through the entire bottle. (This only works if the bottle is asymmetric, though most bottles are.) I could help you more if you give a screen shot of your bottle in isometric. Also, keep this in mind for future projects. Though lofts look cool, if you can avoid them then I suggest you do. They are usually hard to dimension. Almost impossible to properly machine(for high school students anyway). Plus most of these jobs you can do with a combination of revolves and sweeps. I am sorry for getting off topic, just a little advice. I hope this helped somewhat.
Unread 18-01-2008, 10:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Seth
As most have already stated, the correct way to dimension a loft is the same way you sketch it basically. lol I'm assuming you used one sketch around a center line, and then revolved that?
If that's the case, simpley take a crosssection of the bottle as a section view, and dimension the arcs, and center points of said arcs from a central point on the drawing.
Using ellipses are a pain and a bit more tricky, but can be dimensioned as well.
For actual manufacturability of a bottle, certain areas are given dimensions, and left up to the manufacturer to make it "up to snuff" so to speak.
On a 2 liter soda bottle, there is a lot of engineering that goes into them to make sure they are the right strength so they actually hold the amount needed, and also so you have flat surfaces to attach a label.
For instance, the label area is predominatly a straight tube section, while the flow up to the cap, and down to the bottom (sometimes with additional features for design, or structural integrity added onto them (re: the bottom of a 2 liter bottle's 5 points that make their "feet" so to speak.) is a loft type feature.
Btw, as a side note, if anyone in your class there does end up modeling a 2 liter soda bottle, I would love to get my hands on that model in a format I would be able to use in Solidworks. Let me know. I'm sure one of these days I'll actually get around to make my own, but if you can provide me with one that would be awesome.
Unread 18-01-2008, 10:33
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I'm not sure whether you're talking about dimensioning the bottle (i.e. annotation) in a drawing file, or dimensioning the features in the part file in order to control the shape and size. If you're talking about a drawing file, see above.
If you're talking about changing the size and shape of the curves created by lofts:
When making a loft, you can make as many cross-section sketches as you want along the height of the bottle. Create work planes offset a certain distance from the bottom plane. When you choose the profiles for the loft, you can select the entire series of profiles instead of just the beginning and ending profile.
Alternatively, or at the same time, you can use "rails" to control the shape of the loft as it goes between each of the profiles. Create a sketch plane that cuts through the bottle in a vertical direction, then draw lines/curves to make the shape of the bottle's profile (from top to bottom). The ends of that sketch should be contrained to the location of the beginning and ending loft profiles. Then, in the Loft dialog box, click to start a list of "rails" and choose that sketch.
I don't know if you're already doing one of these things, but I think Rails are what you're looking for. You can constrain and dimension the rails to precisely control the path of the loft.
I hope that helps. If you post the Inventor file, I might be able to give a more concrete answer after I can see it.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 21-01-2008, 08:37
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
One method is to Show Sketches (from the model) in the drawing. Of course with an organic design it is not possible to fully dimension - that is why it is powerful to be able to take your solid model data right to CAM software and then to CMM inspection software. The 3D model is the single source of truth.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Learning Dimensioning and Tolerances Madison Inventor 12 14-03-2007 13:56
