Go to Post If you plan the work and work the plan, you will very likely make it to the district championship. - IKE [more]
Unread 17-01-2008, 18:58
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Keyang Motor Spur Gear Pitch
The kit supplied teams with two keyang motors that have different spur gears on the output shafts.
Does anybody know the pitch of these two spur gears?
For reference the part numbers of the two motors are "16627961" and "16631023"
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 21-01-2009, 14:11
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Keyang Motor Spur Gear Pitch
so does any one no this is really frustrating not to have this data and i have looked ever where
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 24-01-2012, 15:00
Cap'N Cap'N is offline
FRC #1711 (R.A.P.T.O.R.S.)
Cap'N is an unknown quantity at this point
Dido, I've tried Wikipedia for sizing info, but I'm still lost
Unread 24-01-2012, 15:23
So far I have found out that Dimetral pitch is equal the number of teeth devided by the circumferance of the pitch diameter.
Unread 24-01-2012, 21:35
hey I found the info you were looking for its on us first webpage all you have to do is search keyang and a motor spec sheet sshould pop up as a result
Keyang Motor Gear Profile LieAfterLie Motors 6 23-02-2007 17:16
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
Spur Gear Rod? David Guzman Technical Discussion 6 18-01-2006 22:53
gear pitch BoticsPUNK Motors 2 19-01-2003 16:53
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
