Go to Post Get your team together. Get your priorities straight. Get busy having fun. See you on the field. - EricH [more]
Unread 18-01-2008, 12:39
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
easyC pro code needed
i found a thread dincluding a C code for mecanum wheels but i'm looking for an easyC pro code.
i'm using 4 wheels drive and i wanna ask if anyone have an easyC pro code for Mecanum wheels 8".
thanks for helping
Unread 18-01-2008, 12:48
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: easyC pro code needed
If you or someone on your team has an knowledge if C and the default code, I wouldnt expect it to be too hard to translate the code from plain C to EasyC. If you post a link to the code, I can help you decipher it.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 18-01-2008, 13:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
http://www.chiefdelphi.com/forums/sh...hlight=mecanum
This is for 4 wheel mecanum.
Unread 18-01-2008, 16:36
yara92's Avatar
AKA: Mohamed
Originally Posted by Kingofl337 View Post
tamra-afr.net
Unread 19-01-2008, 08:38
yara92's Avatar
AKA: Mohamed
I downloaded your program and it didn't work well , it seems to be designed for xbox 360 joystick
can you send me a code for a regular joysticks for 2 ports
thanks
Unread 19-01-2008, 20:05
Kingofl337's Avatar
AKA: Adam
There was a small "bug" in the code the Spin joystick was the same port as the Y translation joystick. I've updated the code but you can just update the version you downloaded.
Download easyC PRO & 2007 Kickoff Code Kingofl337 Programming 1 24-01-2008 09:15
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
Kevin's PWM 13-16 Code in easyC PRO Kingofl337 Programming 0 02-02-2007 09:03
