Movement of the Fisher Price motors
This is a simple and rather dumb question, but suppose one uses the Fisher Price motors to rotate an arm. If one cuts power, does the arm simply dangle, or is it held in place?
Thank you. |
Re: Movement of the Fisher Price motors
How much torque are you dealing with? |
It depends on the weight of the arm. If you are holding up something like 10 pounds it will probably fall back down. It would only stay up if it is light and standing strait up.
it really depends on the torque (gear ratio) and your design of lift, rotation, etc. They dont move that easily without power. However, with a 10lb ball to deal with, I'm sure it will not stand still with a loss of power.
This is actually our first year we dont intend on using those motors for our lift. |
We use a worm gear type reduction for lifts because they are typically harder to backdrive.
It shouldn't be hard to set up an experiment. |
You can put the Victor(s) on "brake" mode which will help a little bit. It might still fall but not as fast. Traditionally worm gear setups don't fall (backdrive). The Van Door motor is the exception.
#7
If I recall correctly, the worm on the vandoor is around 10 degrees. I haven't looked closely at this year's motor, but older versions had an adjusting screw that could be used to increase the drag on the system and reduce a tendency to backdrive. I wouldn't reccommend making it too tight though! |
#8
If you wanted to you could put some kind of a passive lift system to hold your arm up. This would be something like surgical tubing, a spring, or closed actuator. Also you can stall the motor by giving it constant power so it doesn't move. Stalling is not good for the motor if it last more than a second or two. The only issue you may encounter with using a worm gear is that when a match is over you may not be able to put the arm down without power.
#9
If you want it to be stable, use the blue speed reducer transmission... thing.
That's what we did on our robot, and the arm was very stable: http://www.chiefdelphi.com/forums/sh...ad.php?t=56063 You should be able to see it on the third picture. Of course, using the speed reducer it DOES reduce your speed along with the vibrations, so think carefully if you really want to have a stable but slow arm, or fast but unstable arm (or something that's half of each). Hope that helps. |
#10
hey where did u get that blue thing? and how does it work?
#11
Mikhail,
The simple answer is the Fisher Price even when used with the supplied transmission cannot hold itself in place when the power is removed especially with the weight of the arm and whatever it might be holding. You can couple to a worm gear system as some have discussed or you can use a pneumatic operated brake to hold the arm in place. You can even use a servo motor to operate a mechanical stopper, the choice is up to you. |
#12
| are this year's fisher price motors as good as the old ones with the black case? | waialua359 | Motors | 2 | 11-01-2007 22:51 |
| Buying parts for the Fisher-Price motors | KrtZer0 | Motors | 3 | 11-02-2006 15:22 |
| Fisher price motors connected to the relays? | zainali | Motors | 1 | 09-02-2004 18:50 |
| Fisher Price Motors for Drill Motors | archiver | 2001 | 0 | 24-06-2002 00:22 |
