Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 18-01-2008, 21:05
dan2200's Avatar
dan2200 dan2200 is offline
AKA: Dan Causer
FRC #2200 (MM Rambotics)
dan2200 is an unknown quantity at this point
pic: 2200 Finished the Main wiring!!
Unread 18-01-2008, 21:30
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: pic: 2200 Finished the Main wiring!!
The only thing that I wonder about is why you guys choose metal as a base. I would be worried about wires coming uncrimped (/sp) and then shorting out on it.
I win! XD
Unread 19-01-2008, 00:51
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
The chassis is not grounded as per the rules, so it would take both a positive wire and a ground wire to both come loose and to both contact the metal to cause a problem.
Our wires are tied so tightly that this would be almost impossible anyways.
Originally Posted by vhcook View Post
Interesting. You seem to have divided the Rockwell block into two sections. I don't think there's anything wrong with that, but I'm curious why you made that design decision. Did you get an extra grey end-block for the far end (which is out of the shot) so that you don't have to worry about the black blocks sliding?
Yes, we have 4 end blocks.
Are you sure you will have enough room to get the serial cables in and out of the robot controller once this is mounted on/in your chassis? Plugging them straight in needs about 3.5" of clearance, as I recall (although there is the option of right-angle serial adaptors to get you out of that problem).
Where does your backup battery sit?
Yes we have allowed enough room for the cables. the robot extends 3 inches past the end of the plate.
The backup battery mounts to a bracket on the side near the rc.... not in this picture.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 19-01-2008, 00:54
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
We just have 3 speed controlers and 2 spikes right now.. I don't understand how you guys can use 8 or 10??
Begüm
Unread 19-01-2008, 01:01
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
If you're running your drive train with 2 CIMs on each side, that uses up the 4 victors that came in the kit. Then another for any other motors that you'll need for your manipulator or lift system or whatever other mechanism. Also, some teams install a spare 1 or 2 in case one gets smoked during a match it can easily be rewired to a fresh one.
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 19-01-2008, 01:06
beemgruem's Avatar
AKA: Begüm
For my drive train don't I need 2 victors for just 2 CIMs? Am I wrong? Why would I need 4?? And we are having 1 for our lifting actuator.. So that shows three? I am just lost for 2 CIMs for 4??
And also it is a good idea to just replace it.. I think I will use it..
Begüm
Unread 19-01-2008, 01:08
beemgruem's Avatar
AKA: Begüm
Oh never mind Sorry about my bad english.. We are using 2 omni wheels so we are actually connected just 2 of our wheels to CIMs.. So that is okay now
Begüm
Unread 19-01-2008, 01:14
Bochek's Avatar
AKA: Adam Bochek
What you are missing that will help explain what your reading, is that we have 4 CIM's powering our drive train, that uses 4 victors, we also have 4 victors for the manipulator. Notice the lack of pneumatics and spikes?
- Bochek
Unread 19-01-2008, 01:15
Rule of thumb: If it's a motor, it uses a Victor. If it's a piston (or a motor used like a piston), it uses a spike. So, two CIMs per side of the drive, that's four victors. I guess they have four motors for a hurdling device.
In your case, as described in this post, yes, you only need three. Add one per motor added later. (e.g. adding two CIMs to the drive takes your total to five.)
Unread 19-01-2008, 00:55
Bochek's Avatar
AKA: Adam Bochek
also, if you look carefully you can see that it is sitting on our digital scale.
9.7lbs (includes everything except a battery.
Unread 18-01-2008, 21:32
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm assuming your master breaker is also at the far end there.
You've got a fairly clean wiring job there. It looks very nice.
Unread 18-01-2008, 22:01
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
It looks really nice. Someone must have spent a lot of time making the wires look neat.
It looks like the two maxi blocks are connected through one another. Is this right? It if is, then according to R50, there has to be another 6 awg wire connecting it to the Rockwell distribution block.
<R50> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit
breaker distribution panels shall be connected as shown in the 2008 Power Distribution
Diagram. In particular: The battery must be connected to the ROBOT power system through the use of the
Anderson Power Products (APP) connector.  The APP connector must be attached to the battery with either the copper lugs provided
in the FCI Burndy Bag or appropriate crimp-on lug connectors. The battery terminals and the connecting lugs must be insulated with shrink tubing
and/or electrical tape.  The main 120-amp circuit breaker must be directly connected to the hot (+) leg of the
ROBOT-side APP connector. Only one 120 amp main circuit breaker is allowed. This
breaker must not be bypassed.  The power distribution block must be directly connected to the APP connector and main
120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit
breaker.  All circuit breaker distribution panels must be connected directly to the power
distribution block. No intermediate connections are permitted.
Additional lengths of #6 red and #6 black wire may be used to reach the panels as
needed to make the above connections. Circuit breakers must be accessible for inspection at each FIRST Robotics Competition
event.
Oh, and why do you need eight 40 amp loads?
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 18-01-2008, 22:31
MasterMkanik's Avatar
MasterMkanik MasterMkanik is offline
AKA: Cameron
FRC #0619 (CARobotics)
MasterMkanik is an unknown quantity at this point
What do you need eight speed controllers for? We have half that!
He's on the Fruit Loops side of the cereal aisle... if you know what I mean.
My mind works like lightning, one brilliant flash and it's gone
Unread 19-01-2008, 00:43
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
We will require 10....
Unread 19-01-2008, 01:18
Aren_Hill's Avatar
Build Nifty Things
get it right popo its 11 geez
A guy who likes robots.
Team 2200 Year in Review 2007 Bochek Robot Showcase 0 13-01-2008 22:09
the main code Roni2230 Programming 9 10-01-2008 12:14
pic: Main drive mount falconmaster Extra Discussion 2 18-01-2006 20:05
pic: Posing on the finished goal BigPapa Extra Discussion 0 10-01-2006 16:59
pic: Wiring Up the Bus (team 180) CD47-Bot Extra Discussion 1 05-04-2004 01:40
