Go to Post To me, the changing rules are a big part of the fun. If the rules stayed the same year to year, robots would start to look the same. That would be boring. - Richard Wallace [more]
Unread 18-01-2008, 22:55
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Andy Mark Toughbox - Warping Plexiglass
Just a bit of advice to any and all teams using this year's Toughbox from the kit.
Make extra sure you don't over-tighten the four bolts that bind the box together. It's really easy to bend the plexiglass plate. A couple younger members already permanently warped ours. Although, I'm kinda glad they did, because if they warp that easily, I'd rather not have them on the robot.
We're going to have some identical plates made out of aluminum. I'm sure many teams have already realized this, but I figured I'd bring it up anyway.
void function(void)
  function();
Unread 19-01-2008, 02:16
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Andy Mark Toughbox - Warping Plexiglass
Our plastic plate actually seems to have developed some hairline cracks surrounding the CIM mounting screw holes, so that's something to watch out for too. Another reason that an aluminum replacement might be good.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 19-01-2008, 02:43
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
You might consider using the 2" aluminum spacers made for the supershifter from AM in place of the plastic ... and save weight too... win-win
http://store.andymark.biz/am-0127.html
Unread 19-01-2008, 04:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Remember, DO NOT use regular Loctite on anything that may come in contact with Lexan (polycarbonate).
Loctite causes a reaction/dissolves the polycarbonate, which makes it brittle and very prone to cracking and shattering.
The entire polycarbonate plate is needed, because it holds the bearings and supports the shafts. However, you can use the aluminum spacers in the link you provided in place of the extruded aluminum box around the transmission.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2008, 13:19
void* Jake;
FRC #1178 (DURT)
On a similar note, can anyone do me a big favor by e-mailing me the Autodesk schematic drawing of that plate, so we can send that to the shop guy? We've yet to set up Autodesk on any of our machines and we can't get ahold of the one who owns the FIRSTBase manager account, so we can't get it ourselves right now.
If you can send it to jakenveina@yahoo.com
void function(void)
  function();
Unread 19-01-2008, 15:52
in between teams
AKA: Luke Van Oort
You can download an *.stp of the gearbox from AndyMark. You could also just make a new model of it from the drawings at AndyMark; it isn't a very complicated part.
Team 1219: 2009 - Mentor
Unread 20-01-2008, 15:58
void* Jake;
FRC #1178 (DURT)
I know I can download it from the website. We don't have the Autodesk software setup and it's going to be a while before we can. If I could do it myself, I would.
void function(void)
  function();
Unread 20-01-2008, 16:09
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
An AutoCAD 2000 drawing of the polycarbonate plate is in the attached ZIP archive.
--Madison--
...down at the Ozdust!
Andy Mark Traction Wheels? Deepthought2491 Technical Discussion 10 15-01-2008 13:09
Andy Mark (reliable???) cobrawanabe1699 Technical Discussion 31 15-01-2008 12:55
Andy Mark Battery Plugs Fab.Master General Forum 0 05-01-2008 22:44
Andy Mark Transmissions Drawings vVigglEs Inventor 8 18-01-2007 20:08
Andy Mark Planetary + side load Salik Syed Motors 10 30-01-2006 21:53
