Need help in Kevin's 2008 default code
After downloading this code to the processor, it looks like the program never calls function Process_Data_From_Master_uP(). I saw it in main(), but when I add printf() to test it, it never shows up...
Re: Need help in Kevin's 2008 default code
-Kevin |
I believe it is in the User Routines under the frc_gyro folder.
It sounds like you are using older code and not Kevin's 2008 code.
shouldn't all posts about kevin's 2008 code be moved to the thread stickied for the purpose of discussion?
I think that's a typo... By the looks of it this is about last year's KWatson code...
| 2008 Default Code? | Demothesis | Programming | 11 | 11-01-2008 21:50 |
| need help with our default code | coolguybigt | Programming | 14 | 19-02-2007 10:17 |
| Problems with Kevin's 2007 default code | bruss6 | Programming | 8 | 19-01-2007 15:42 |
| What are with the Ls in Kevin's code??!!! HELP!!! | RbtGal1351 | Programming | 2 | 18-02-2005 16:57 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
