Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 19-01-2008, 14:07
Jonathan W.'s Avatar
Jonathan W. Jonathan W. is offline
FRC #1351
Jonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura about
Angry Hole Tolerance Help Needed.
Does anyone know the tolerance dimension for an axle hole of .5 diameter?
We will be using bearings in the wheel pods, so there will be no bearings in these holes, and the axle is not spinning. We want to be able to slide the axle out for quick maintinace, so it cant be too tight of a fit (not press fit). None of our ppl know this magic number...
Unread 19-01-2008, 14:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hole Tolerance Help Needed.
It depends on how tight is tight, and how loose is loose.
If your axle is exactly 0.500 inches (measure it!), then 0.010 clearance will be a loose enough fit so that it slides out with no effort.
"Officially" there are machinist tables that list the class of fit and the tolerances necessary, but that's way beyond your question.
My best suggestion is to just drill a hole and see if it's loose enough - if not, use some sandpaper to open it up a little until it's OK.
As an alternative: Test bore several holes and try them with a piece of axle. Then report what you found here for the rest of us.
Don
Help Needed. Mars FIRST Lego League 3 30-12-2007 14:03
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
Help needed.... Pin Man General Forum 9 02-06-2003 20:40
Tolerance of Breakers Ben Mitchell Technical Discussion 2 01-02-2002 09:48
Inventor 5.0 help needed Larry Barello Inventor 4 27-01-2002 10:54
