IR Sensor
On the IR board, do we connect the output signal to positive or signal on a PWM cable?
SVP Thank you. |
Re: IR Sensor
If you are referring to the pins that send data from the ir board to the robot then yes. Those should be connected to the white cable on the pwm cable. Also make sure to hook the black part of the pwm cable up to a ground wire on the board.
| Sensor | Molten | Programming | 3 | 17-02-2007 17:43 |
| Banner Sensor | Wstedtlogan | Electrical | 1 | 20-12-2004 17:21 |
| Sensor or no Sensor For Autonomous mode | Kyle1010 | Programming | 14 | 22-01-2003 13:10 |
| Sensor Q | Brew | Technical Discussion | 2 | 10-02-2002 12:48 |
| Sensor | Oakridege_665 | Technical Discussion | 5 | 10-01-2002 16:53 |
