Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 20-01-2008, 10:45
bekahg bekahg is offline
FRC #1752 (Tonka Robotics)
bekahg is an unknown quantity at this point
Trouble connecting power
I looked online to find out how to connect the battery to the power adapter. I can't find it anywhere! Can anyone tell me how to do it?
Unread 20-01-2008, 22:57
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Trouble connecting power
I just went through this myself...
First of all, from what I've read, the only allowed battery is a 7.2v battery pack such as the one used as the back-up battery on the RC. For testing, though, you could use a 9v transistor radio battery (009P style)
The coaxial connector is included with the chicklet. If you don't have it or need another, they are available from many sources such as Radio Shack. I don't know the exact size, so bring it with you and they'll find one that fits.
The Positive connection connects to the center of the plug. The negative goes to the outside. You will need to unscrew the cover of the plug, place the wires through it and solder them to the tabs inside. (I just read in another post that the chicklet is protected against reverse polarity. But do it right the first time and save messing up the tiny connections in the plug!)
There is very little room for the wire and soldering. I suggest a small, pointed solder iron and use care to solder the wires neatly using the holes in the tabs. Use small (18-22 ga.) wire. I also recommend some heat shrink tubing over the center tab so they don't short out. It was a tight fit when I did mine.
The 7.2v battery pack has a 2-pin connector similar to a molex connector on it. I haven't found a place to buy those exact connectors, so I used a spare back-up battery pigtail with the push-on crimp connectors, then put two male crimp-on (tabs) connectors on the coaxial plug lead. It's a kludge, but leaves the battery and pigtail unmodified. The battery can still be charged using the standard charger.
Next step here is to mount the chicklet and battery in a small plastic box for protection and build a short 15-pin cable to extend it to the port on the OI.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 21-01-2008, 10:56
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
The connectors and pins are available from IFI
http://www.ifirobotics.com/ifi-store.shtml
PWR-CONN-BATTERY
PWR-CONN-CHARGER
I also believe that these are the same from Jameco
Backup Battery Plug (goes on the battery)
http://www.jameco.com/webapp/wcs/sto...oductId=527056
Backup Battery Receptical (goes on the RC)
http://www.jameco.com/webapp/wcs/sto...oductId=527187
Backup Battery Male Pins
http://www.jameco.com/webapp/wcs/sto...oductId=526133
Backup Battery Female Pins
http://www.jameco.com/webapp/wcs/sto...oductId=526150
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Connecting 7.2V (directly) to camera scottmso Programming 15 14-01-2006 23:13
Connecting the controller Max Brin Technical Discussion 1 12-01-2006 11:24
Connecting Switch to RC Mr. Steve Control System 2 28-01-2005 22:37
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
