mplink errors in eclipse
I tried using eclipse ide for code development. But I get a funny error during the mplink step. I tried the same mplink command from a shell and that works fine. Why does eclipse cause this problem?
Here's the build error from eclipse. Building target: BallBot_2008.hex Invoking: MPLINK Linker mplink "..\18F8722.lkr" /a INHX32 /w /m FRCMapfile.map /o"BallBot_2008.hex" ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /l"C:\mcc18\lib" ..\FRC_library_8722.lib MPLINK 3.90, Linker Copyright (c) 2004 Microchip Technology Inc. Error - unrecognized input: C:/msys/1.0/a Errors : 1 make: *** [BallBot_2008.hex] Error 1 |
Re: mplink errors in eclipse
My environment is eclipse on Windows XP.
I saw the same problem after installing msys (in order to get the rm command to fix the "clean" problem with eclipse) I uninstalled msys and switched to GnuWin32. Everything is fine now. |
| Visual Studio C18/MPLINK build rules >>>HERE<<< | itsnotabigtruck | Programming | 4 | 03-03-2008 07:48 |
| Build problems: MPLink 4.15 Linker... help? | Trav-O | Programming | 2 | 12-01-2008 14:26 |
| Mplink error | jimmyrock88 | Programming | 2 | 14-11-2007 15:50 |
| "Full screen mode" in Eclipse/Easy Eclipse | Kelly | Programming | 0 | 15-07-2007 16:37 |
| MPLink Error | cloudago | Programming | 2 | 01-02-2005 23:00 |
