Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 21-01-2008, 16:50
JustineSHA JustineSHA is offline
FRC #2437
JustineSHA is an unknown quantity at this point
Exclamation Help!! Moderating Turns in OI
We can make a tank turn, but we want to turn smoothly with both motors going forward in a desired speed. If anyone can help us, please reply to this thread!
PS: We're using EasyCpro
Unread 21-01-2008, 17:17
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Help!! Moderating Turns in OI
Can you describe your problem in a little more detail?
1. What sort of drive train are you using? 2WD? 4WD? 1 transmission per 2 wheels on each side?
2. When you say you can turn, do you mean one side drives forward while the other side reverses? Or when you are attempting a forward turn, does one side lock up?
3. Is it hopping? Skipping?
4. What kind of wheels are you using?
5. What is the surface you are testing on?
6. Is your robot at full competition weight?
You get the idea? Without actually being there, you have to provide as much information as possible so that the geniuses here can help you out
Unread 21-01-2008, 20:11
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
If you mean you want both sides of the robot to move at the same rate without a large amount of driver micromanagement then you should probably use encoders on your wheels and then use a PID loop to keep the wheels turning the same speed. There are many helpful white papers on PID loops. If you still need help after reading those I'll hook you up with my teams programmer.
Moderating Acceleration / Deceleration Tom Line Programming 7 15-02-2007 13:39
Video Game Legend Turns 25 JoeXIII'007 Chit-Chat 3 16-06-2005 12:58
Bouncing turns bob1million Technical Discussion 34 01-03-2004 16:40
