Go to Post Conspire to Inspire despite what may transpire ! - Bill_B [more]
Unread 22-01-2008, 13:03
CollmandosGrl CollmandosGrl is offline
None #1466
CollmandosGrl has a spectacular aura aboutCollmandosGrl has a spectacular aura aboutCollmandosGrl has a spectacular aura about
Gear question CAD
Is there a way to specify all the gear constants I've created into inventor somehow - and it to generate that gear?
I have the circular and diametral pitches,addendum, dedendum - and practically everything else.
Does such a plugin or some extention of CAD exist that i can do this quickly - or do I need to do model this myself?
Unread 22-01-2008, 13:19
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Gear question CAD
Check out Ed Sparks' iSpurGear model on http://firstcadlibrary.com/ . You can find it at the bottom right side of the 'Gears' page.
iParts contain model data for a number of different variations of a single part and allow you to generate what you need based on that data. If you were to create an iPart yourself with the data you have on hand, you'd probably end up with something that's quite like Ed Sparks' model.
Otherwise, to my knowledge, there is no 'wizard' or similar in Inventor that prompts you for the gear dimensions and generates a model from them.
--Madison--
...down at the Ozdust!
Unread 22-01-2008, 13:51
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I've always just modeled them myself. They don't take that long with the circular pattern and are great practice.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 22-01-2008, 16:07
pmax's Avatar
pmax pmax is offline
AKA: Peter Maxfield
pmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to all
Indeed their is; it is called "Design Accelerator."
When you are in an assembly, change your browser drop-down (the title) to Design Accelerator, and you should see a new set of tools in the toolbar palette. One will be a gear set generator.
Of course, the FIRST CAD library is also a good place to find iParts as well.
www.autodesk.com/first
Unread 23-01-2008, 09:43
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
To expand on Pete's reply, to use the Design Accelerator you must have access to the Content Center libraries. These are installed during the Inventor installation process. Your project must also be set up to use the libraries.
Gear usage question Tottanka General Forum 4 08-02-2007 15:35
gear question kevin.li.rit Technical Discussion 2 13-01-2007 19:40
Tech Question About CAD and RP indieFan Chit-Chat 2 23-07-2004 12:35
Gear reduction question dmellich Motors 6 25-01-2003 08:54
Gear Box Parts Posted on First Cad Library Ed Sparks Inventor 1 10-01-2003 01:54
