Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 23-01-2008, 10:55
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Color Sensors
Does anyone have any experience with color sensors? We are looking at ways of controlling the length of belts and bands by placing colored or reflective tape at stop and start points. We have never used sensors outside of the KOP. How can we make sure what we get is compatible with the control system FIRST uses?
Unread 23-01-2008, 11:11
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Color Sensors
I used color sensors for a marble sorter for PLTW and hated it. I never got mine to work. Good luck and hopefully the next person will have advice on the matter.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-01-2008, 11:36
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: Color Sensors
If your belt is a uniform color then you can use contrasting paint to mark a line and sense is with a photoresistor. An example is a white line painted on a black belt. There are tons of examples online for line-following applications. The circuit uses a photoresistor or phototransistor in a voltage divider. To make it even easier you can get a pre-packaged unit like this:
http://www.acroname.com/robotics/par...E-LINE-IR.html
Unread 23-01-2008, 11:50
Re: Color Sensors
If the sensor provides an analog signal from 0-5 volts, the RC analog inputs will accept it without problem. If the sensor provides a digital signal of either 0 or 5 volts, the RC digital inputs will accept it without problem.
The kit of parts in previous years included optical sensors from Banner. The output was an "open collector" transistor circuit, essentially a contact closure to ground. The RC digital inputs have an internal pullup resistor to +5 volts, so they work with that type of sensor without problem as well. (That's what this year's Gear Tooth Sensors provide.)
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Finding color brownster Programming 1 20-02-2005 03:23
Color? neilcooper Technical Discussion 2 11-01-2005 16:58
how well do the sensors pick up color? Kyle Technical Discussion 15 10-01-2005 12:31
