Go to Post Team Titanium's trying Teeter Totter Talons tying the terrain traversal tandoming Twin Tucking Tabs to try triples. - [more]
Unread 24-01-2008, 15:09
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
mounting accelerometers & gyros
What kinds of mounting schemes have been tried to dampen the vibrations from the robot to these sensitive sensors? What kinds of materials seem to work best? Rubber, foam, other materials?
TIA
Unread 24-01-2008, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: mounting accelerometers & gyros
Certainly non-conductive materials!
In the past we have mounted gyros and accelerometers with screws and nuts onto a thin (<1/16") metal plate, with a thin (1/8") piece of hobby foam sandwiched underneath. The screws were not too tight (so the solder points below didn't punch through the foam), then we used blue thread-locker to make sure it stayed. The metal plates were then mounted to the robot frame as necessary.
Don
Unread 26-01-2008, 20:10
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks for the input Don. I have them mounted with a rubber washer dampening the vibrations. I'll let you know how it works out.
Gyros EROCK Kit & Additional Hardware 10 21-01-2008 18:58
Where to get the KOP accelerometers? Billfred Kit & Additional Hardware 0 19-11-2005 10:15
The accelerometers Validius Programming 9 21-03-2005 08:22
pic: The Bobcats 2001 &amp; 2003 &amp; Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
