How would you machine this?
We need to cut a .75" wide slot all the way down a 60" piece of .75" x 1.5" x .125" box aluminum. This slot needs to be as accurate as possible. What would be the most accurate way to do this?
Re: How would you machine this?
A large milling machine could do it, or if you set up a smaller one so you can move the piece after you make part of the cut, then that should work too. It will be kind of challenging to set it up. You probably want to make sure the work is clamped in several places so it can't flex, and that the clamps are set up so they won't move as you reposition the work on the bed.
This year we are going to a lot of trouble to make our robot with a cordless drill and a hacksaw....just because of the fun problems like that we've faced in the past. |
If you have access to a horizontal mill with a long enough table, you could just bolt the piece directly to the table and use a 3/4in cutter. You'd have it done in one pass and it'd be almost dead on. Just make sure the piece is square to cutter.
Now, if you have the sides accurate enough, you could do it in two or maybe three passes. Pass one: one end to about the middle. Make sure the vise or other holder is straight first, though. Pass two: Move the table back to start. Move the part to the middle, using the quill to help align. Repeat first pass. Do not have the tool contact the metal when you start! Pass three: Repeat pass two. |
How about a metal blade on a table saw? To get the 3/4" slot you may need to rip it twice, but it should be fairly accurate. You can always plug the extrusion with some wood after the first cut to keep it straight and true. Metal blades aren't cheap, but neither are 5' travel horizontal mills...
Bengineer |
Is this to lighten the part, or is it a track for something to move in?
A manual mill may do it like eric said if you can keep the vice straight. I also like Ben's idea of a table saw. |
#7
Thanks for all of the quick replies! Last edited by Tapoore : 25-01-2008 at 14:46. |
#8
Laxphan,
We regularly cut 1/8", 1/4", and 1/2" thick aluminum on our table saw here at work. It is, obviously, a little more heavy duty than your run-of-the-mill consumer table saw. But with the proper tooling and use, a table saw can certainly cut aluminum material. I'm not saying that I'm the one doing the cutting, as I know that I am not experienced enough to work with the thicker materials. But, it can be done, and could actually provide the precision that is asked for in this application. Bengineer |
#10
The shape you are looking for could presumably be formed from 3 pieces. A C-channel and two pieces of L angle. Rivited, welded, whatever.
#11
As for my personal solution to machining this object you two option if you have access to mill you can mill the slot in two passes with 3/4" 2 flute mill bit by flipping the piece around. You should have no trouble doing this on any stage 1 or 2 bridgeports 9" x 41" tables. However if you dont have a nice mill. you have another option. We have a dewalt router about 4hp that we can put mill bits in for doing similar processes. If you go this route you need to create a jig to clamp the work piece and also a guide for the router to follow so it stays on the same cutting path. The mill is a far better option but we have used the router before and it works great much better than a table saw ever would. However you need the correct machine for any process therefore a 3/4 hp router is made for cutting wood not cutting metal. |
#12
The most accurate way to do this would be do mill it on a manual vertical mill. Almost any way you do it you will have to do multiple passes. There are vertical mills out there with beds longer then 60" but they are few and far between. If you want to minimize the number of passes that you wil have to make. You could make a really big vise out of two pieces of precision ground bar stock The first one you would drill holes in and then bolt to one of the slots of the mill. If you buy a precision ground flat stock bar you should be able to find one that will key into the t-slot of the vertical mill that you are using. The second bar you would use as the moveable jaw and use cam action clamps to move the moveable jaw into the fixed jaw. Like the ones found here http://www.miteebite.com/products/multi-fixture_e.html The other approach is to use multiple vises. The big thing is that you need to set it up to be as even as possible across the vises. An easy way to do this would be to clamp the vises on to a piece of bar stock and then using a test indicator to run along the edge of the bar and adjust the vises until the dial does not move along the length of the bar. The biggest problem with this machining task is that you will be turning a ridged piece of box tubing into a not as ridged piece of channel. So in order to compensate for the material that you are removing you will need to make a couple of blocks that you can slide inside the tubing so that you have something to clamp down to so that the tubing does not deform under the clamping pressure. If the sides of the tubing bend in under the clamping pressure that would cause the .75" slot the you mill to become wider once you release the clamping pressure. I would also mill the slot in two passes. I would not use a .75" cutter I would use a .5" cutter over two passes. This allows you to compensate for clamping deformation, and actual cutter size. It would be even more accurate to mill this on a horizontal mill using a slitting saw. But good luck on finding one I don't know anyone that has one. But there are vertical to horizontal adapters for bridgeport mills that you can buy. I have mill long slots in pieces of tubing and had to move and reclamp multiple times and it turned out fine it just took forever. What type of tolerance are you trying to hold? If you are planning on using this piece of box tubing in an elevator design it is not a bad idea to design in a degree of play so that the elevator does not bind as it goes up and down. Also please note that this piece of channel that you are making could easily deform under dynamic load and duing the competition. I understand the desire to hold as tight of tolerance on machined parts as possible but just make sure that you don't design yourself into a corner by demanding that they stay that way. I guess the moral of this story is that it is possible to make it as accruate as you want to pay for. |
#13
Yeah most likely would be a large cnc mill or a horizontal mill with a little programming put into it. That would help.
#14
You might look at this link. I am not suggesting using this but, it is designed for a table saw to cut aluminum
http://justsawblades.com/systimatic/hsr_gold.htm |
#15
| So how would you fix this year's game? | AnonymousMan | General Forum | 6 | 09-01-2005 09:36 |
| How much would you pay - Championship? | Steve W | General Forum | 2 | 03-06-2004 19:20 |
| How much would you pay - Regionals? | Steve W | General Forum | 10 | 03-06-2004 19:18 |
| Would you like to learn how to sign? | OneAngryDaisy | General Forum | 0 | 05-03-2003 20:11 |
| Buckeye Regional: How would you judge? | Wayne Doenges | Regional Competitions | 6 | 21-03-2002 21:33 |
