Go to Post If you do mentor FIRST, be an asset to your team, but know that your students will admire you all the more if you set an example and finish your own homework. - Eugenia Gabrielov [more]
Unread 27-01-2008, 15:03
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Global variable question
If I create a global variable in one .c file, can I access this variable from another .c file?
I thought so, but I get the error "symbol 'varname' has not been defined."
Thanks,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 27-01-2008, 15:09
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Global variable question
In one file, define it like this:
int foo;
And in the other file, define it like this:
extern int foo;
In the first file, it will define the variable, and allocate the memory space for it. In the second file, it will define the variable, but know that the memory space for it is external to that module.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 27-01-2008, 15:56
Nathan's Avatar
Great, thanks!
Nathan
Unread 27-01-2008, 18:02
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
A simple way to make sure this works in all files is to add this to a header (.h) file:
#ifdef DEFINE_VARS
extern int foo;
#endif
#ifndef DEFINE_VARS
#define DEFINE_VARS
int foo;
#endif
So, what does this do? You have some macro, DEFINE_VARS. If it has already been defined, you declare extern int foo. If it hasn't been defined, you define it and declare int foo. This way, foo is external for all files but one.
I hope this helps.
Global Variable Placement robbrad Programming 1 23-01-2008 00:50
Stupid Variable question.... BillyJ Programming 3 20-02-2006 19:49
Beginning programmer: Variable question HELP!!! Calvin Programming 4 03-02-2006 18:12
Camera variable scope question Validius Programming 1 28-01-2006 09:24
