Go to Post Batteries are like clamps or money, you can never have enough. - IndySam [more]
Unread 28-01-2008, 16:55
joshyboy9987 joshyboy9987 is offline
FRC #0706
joshyboy9987 is an unknown quantity at this point
Timers and MPLab
So, this is my first year using MPLab instead of EasyC and I was wondering if there was a way to access a hardware timer at all. I know it can be done, cuz EasyC has a function to do it, but I couldn't find anything on the forums.
Unread 28-01-2008, 18:15
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Timers and MPLab
It's relatively easy. Which version of the code are you using (Kevin's new code, or the 2007 default code)?
The basics are in http://www.ifirobotics.com/docs/time...004-jan-14.pdf
But basically you setup the timer, create an ISR that updates some timer variables, and a set of functions that let you read the timer values.
Unread 28-01-2008, 18:19
FRC #0706
Thanks a lot... I'll read through that stuff tonight and see what happens. We're using the default code.
Unread 03-02-2008, 16:01
TechnocratiK TechnocratiK is offline
AKA: Patrick Diez
None #0296 (Northern Knights)
TechnocratiK is an unknown quantity at this point
Are all the timers on the PIC18F8520/8722 (TIMER0-4) available for our use, or are some reserved for use by the IFI code?
TechnocratiK out.
Unread 03-02-2008, 16:53
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
I'd stay away from TMR0. Its referenced from some routines in ifi_library.c (within the high priority interrupt).
Unread 04-02-2008, 10:04
AKA: Patrick Diez
I'm going to answer my own question here. In the IFI 2004 Programming Reference Guide, on page 28, it says that all timers are available to the user for programming, so hopefully that still applies to the 18F8722. I'll post again after some more testing (notably, when I have a chance to get the values of the TxCON registers during initialisation and runtime). Thanks for your input.
TechnocratiK out.
Unread 04-02-2008, 10:10
Be sure to use the ifi library FRC_alltimers.lib, rather than FRC_library.lib.
FRC_library.lib in the default code does use Timer 0, but not for any reason you'd probably care about.
Unread 04-02-2008, 10:12
AKA: Patrick Diez
Huh... so that's what that's for. Thanks for the tip, that definitely removes all doubt about which timers to use.
TechnocratiK out.
A warning regarding MPLAB and find/replace Tom Line Programming 0 24-01-2008 17:35
Timers and Such Inverted Programming 5 19-02-2007 16:08
MPLAB Help, programming and compiling RedOctober Programming 2 23-12-2005 17:46
IFI Loader and MPLAB HolyOne207 Programming 5 14-01-2005 14:19
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
