Go to Post I think he GDC is just rick-rolling all of us. - z_beeblebrox [more]
Unread 28-01-2008, 19:26
bbr4d3r's Avatar
bbr4d3r bbr4d3r is offline
FRC #0020 (Rocketeers)
bbr4d3r is an unknown quantity at this point
Trouble: AndyMark Mecanum wheels
Has anyone experienced any trouble with the AM Mecanum wheels bending during normal game-play like usage?
Unread 28-01-2008, 19:34
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: Trouble: AndyMark Mecanum wheels
I have not heard of this before. What size if wheels are they?
I win! XD
Unread 28-01-2008, 19:40
bbr4d3r's Avatar
6 Inch wheels
Unread 28-01-2008, 19:46
Quasar Navigata Quasar Navigata is offline
Lead Mentor
AKA: Mike Andrews
FRC #1831 (Screaming Eagles)
Quasar Navigata is an unknown quantity at this point
Cool Re: Trouble: AndyMark Mecanum wheels
Last year's bot had a problem with twisting and bent the carrier plates. The conclusion we came to is that you need hubs on both sides to help keep the plates aligned. The key slots may not line up but you only need one hub engaged to drive the wheels.
Last edited by Quasar Navigata : 28-01-2008 at 19:48. Reason: missed a conjunction
Unread 28-01-2008, 19:49
bbr4d3r's Avatar
Are you suggesting hubs that are large that match the circumfrence of the twisted and bent carrier plates almost like reinforcing the wheel?
Unread 28-01-2008, 20:12
shock190 shock190 is offline
AKA: Andrew
FRC #0190 (Gompei and the H.E.R.D.)
shock190 is an unknown quantity at this point
No, what he meant is that a single hub makes the wheel itself carry the torque between the two plates of the wheel. If each of the plates has a hub, then the torque is carried by the driveshaft, which is far stronger than the wheel for this type of loading. This should eliminate twisting damage, unless the shaft itself gets twisted.
Team 190 - Building the ridiculous since 1992
2008 BAE Granite State Regional Leadership in Controls
2008 Silicon Valley Regional Creativity Award
2007 World Champions (with 987 and 177)
Unread 28-01-2008, 20:27
Lead Mentor
AKA: Mike Andrews
Exclamation Re: Trouble: AndyMark Mecanum wheels
No I am suggesting just the hubs like Andy Mark supplies. I should mention we used 8 inch wheels which were the only ones available last year. No the hubs are not for use as side bolsters for strengthening but for alignment. Without the hub on one side you are relying the torque of the bolts to hold the wheels square and that when you assemble the rollers they will be equal length. What happens is as the wheels are used you get a racking motion as that non hub side floats back and forth (not supported by the shaft) and soon the nuts loosen and when you do a quick reversal of direction the inertia can twist the plates.
AndyMark Wheels Andy Grady Inventor 2 05-02-2007 16:49
AndyMark Mecanum whytheheckme Technical Discussion 5 27-01-2007 23:57
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
pic: AndyMark Mecanum Wheels Madison Technical Discussion 13 09-10-2006 00:29
AndyMark Omni Wheels Wayne Doenges Technical Discussion 11 25-01-2006 23:54
